Making A Melamine Box - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-20-2011, 02:51 PM   #16
Just call me Andrew
Rewards Points: 1,020
Originally Posted by dadflynn View Post
Sounds like you didn't nail the unit even with the sheetrock when you installed it. It might be easier to remove the moulding, reinstall the unit even with the sheetrock then reinstall your moulding. This would require you to cut away the sheetrock at least the width of your shelf thickness.
Other then that, you did well.
Actually, I didn't nail the unit in at all. It's just sitting on a shelf inside the closet. I wanted the shelf unit wider than the hole in the wall to try and mask some of the cables a little (I put 2 outlets in the shelf, on the rear of the right side).
For now, I bought a plastic j-channel to cover up the exposed drywall edge, and I will put a piece of quarter round on the top edge. Thanks for the help.
Andrew
secutanudu is offline   Reply With Quote
Painting a Banquet Table (Melamine Surface) jessi1 Painting 4 10-14-2011 02:57 PM
Thinking about making concrete pavers - a few questions Luis C. Building & Construction 16 06-10-2011 05:45 PM
paint banister with melamine? lenster007 Painting 5 03-07-2011 10:34 AM
Need help making a 'back band' around window/door casing. RickDel Carpentry 3 07-15-2010 03:13 PM
Spray Melamine Paint atw58 Painting 9 02-13-2010 08:40 AM
