Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-05-2010, 10:45 AM   #1
Mom to Many, Wife of 2
Send a message via AIM to poorenspirit
Question
Making a faux pantry/secret door- Need Advice
We are remodeling and placing a passage way from our kitchen into a newly constructed laundry area in our garage. We want to place a door up to make a distinctive room, however since we already have two doors in the kitchen (the back and the door that leads to the garage) we are opting to make the final door more similar to our existing cabinetry.
We are planning to construct a faux pantry. We plan to use:
_four of the same sized pantry doors measuring 40 inches a door
_plywood
_cabinetry veneer
_crown moulding
Most purchased from Habitat Homestore very cheap.
1. Since we are creating an opening into a load bearing wall, we must place a header up, then two support studs. I am choosing 2x10s and allowing them to protrude from the wall at least 5-6 inches to attach the pantry doors to them. The doors will extend above the opening and then veneer will be place on exposed studs. And crown moulding will be attached to the studs and appear to be attached to the doors in front of it. A faux toe kick (if that's whatcha call it) will be placed on the doors to give the appearance of a full pantry.
2) We will mount solid wood swinging doors (with special door hinges) as regular doors, then paint the fronts to match existing cabinetry or place regular cabinet doors on the solid doors.
My question is:
Does this sound like a good plan?
Please make suggestions. We are by no means professed experts, just average DIYers.
poorenspirit is offline   Reply With Quote
Old 03-07-2010, 01:59 PM   #2
_plywood
_cabinetry veneer
_crown moulding
1. We will mount (with regular door hinges) the doors onto the plywood in two sections (two doors vertically placed on each side, so the doors will open French door style)using adhesive and tacking brads. A lip will be left on one vertical side to close any gap between the two sides.
2. Since we are creating an opening into a load bearing wall, I must place a header up, then two support studs. I am choosing 2x10 or 12s and allowing them to protrude from the wall at least 6 inches to attach the pantry doors to them. The doors will extend above the opening and then veneer will be place on exposed plywood and studs. And crown moulding will be attached to the studs and appear to be attached to the doors in front of it. A faux toe kick (if that's whatcha call it) will be placed on the doors to give the appearance of a full pantry.
My question is:
Are you planning to make a laundry room door that looks like a door to a pantry?
Or go you mean it would be a swing out pantry, that would allow access to the laundry room?
Old 03-07-2010, 11:29 PM   #3
yeah, sorry - I am confused as to the question.
Old 03-08-2010, 08:49 AM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
You just make it look like a pantry cabinet. If you want, you can put a plain door there, because one more is not going to make a difference, or just use a Pocket door, if you do not want one to swing in or out of the space.
gregzoll is online now   Reply With Quote
The Following User Says Thank You to gregzoll For This Useful Post:
poorenspirit (03-11-2010)
Old 03-11-2010, 03:08 PM   #5
I very much like the secret door concept and also the ability for the door to double as a storage for mops, brooms, etc.
Yes, it will lead into the laundry room. At this point, I have plans to allow it to open like a French door in toward the kitchen. I am taking into consideration that one day appliances will be replaced by someone, whether me or future owners. Opening toward the kitchen will help get them out easier as well as making it easy to take laundry out.
My question is, does this sound like a structurally sound plan to proceed with the project as I have described?
Old 03-11-2010, 03:14 PM   #6
Smile
I want to make it look like a shallow pantry, but it will be essentially be double doors with a broom/mop holder on back and a passage into the laundry room.
Tags
faux door, load-bearing wall, pantry, remodel kitchen, secret door
Faux stone exterior wall by pool - advice please! t3w Building & Construction 5 03-02-2010 09:54 AM
I need alot of advice on making corner shelving Funchal Carpentry 4 11-26-2008 11:25 PM
