Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-31-2011, 09:30 AM   #1
Making dado cuts before cutting sections?
Hey everyone,
I'm new to the board, and new to woodworking in general. I plan on making some bookshelves to use as a room divider, and I have a question regarding dado cuts. I will be using 3/4" Birch and MDF, and I was wondering if I could make the dado's before I cut the sheets down to sections. Will cutting across the dado create a ton of chip out? Anyone have any experience trying this technique? Thank you.
thekillabeejc is offline   Reply With Quote
Old 03-31-2011, 01:23 PM   #2
Originally Posted by thekillabeejc View Post
Hey everyone,
As long as you have the job planned out, there's no reason not to dado the whole panel. Just realize you need to maintain constant support on this sheet or it could possibly snap where the dadoded out wood was removed.
To eliminate chip out, use a router with a spiral bit and a jig.
Ron
Old 03-31-2011, 03:35 PM   #3
uva uvam videndo variafit
WirelessG's Avatar
Like Ron said, make sure you plan it out 100% first. Cutting across the dados will not cause a lot of tear out unless you are using a a dull blade. Personally, I like to cut all my parts to size and then worry about dados, mortises, slots, etc.
WirelessG is offline   Reply With Quote
Old 04-01-2011, 07:15 PM   #4
I'm working on a project like this right now. I cut everything to size first, and then cut the grooves with a router and a jig. Make sure everything is tightened on the router, or you'll find the bit going right thru the material!
mrgins is offline   Reply With Quote
Old 04-01-2011, 08:05 PM   #5
Super Moderator
I like to cut the dados first --the rip the sheet----However,my table saw is huge---
Ron is right about handling a sheet with dados cut---you can crack the thing without adequate support.
oh'mike is online now   Reply With Quote
Old 04-03-2011, 05:52 PM   #6
Thank you everyone for your input. I plan on laying the plywood on a sheet of foam insulation board and making the dados then ripping the sections down to size with a circular saw. I was originally going to try and make the dados with the circular saw and chisel, but now I'm thinking I might invest in a cheap router. Would a 8.5 Amp/1.5 HP Router be powerful enough to make the dados?
Old 04-03-2011, 06:24 PM   #7
WirelessG's Avatar
That's a lot of material to remove and your are cutting on both sides of the bit at the same time. I imagine a 1/5 HP router would be taxed pretty hard.
cutting crown molding for cope cuts billyg Carpentry 6 05-04-2009 07:18 PM
Freezer not making ice after cutting off water thedarkhalf General Discussion 2 03-08-2009 10:09 PM
Cutting pressure treated landscape timbers; the cuts ? Sven Landscaping & Lawn Care 6 01-20-2008 08:35 AM
