Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-09-2009, 05:32 AM   #1
Smile Making ATX computer case of Wood/Partex boards
I am planning to make an ATX computer case with wood or partex. Does anyone have any experience? Anybody to provide any idea.
I am very new to DIY and woodwork things. Doesn,t really know where to start and what tools to buy to start with.
I have planned to buy Black & Decker RTX-6 for the start. Is it enough for making the computer case from wood? Is this multipurpose tool very useful or there are better ones?
RTX-6 tool link: http://blackanddecker.com/ProductGui...ProductID=7767
Thanks all,
Iconsort
iconsort is offline   Reply With Quote
Old 07-09-2009, 06:14 AM   #2
Tool Geek
PaliBob's Avatar
consort, Welcome to the forum and to the world of Tools Before buying any power tools I suggest a good set of hand tools. What tools do you have now?
An ATX Computer Case is not a good starting project because they are made from metal because they need to hold a lot of standard size parts with wiring between the parts. They are also very cheap so they are really not practical for a DIY project.
http://www.geeks.com/details.asp?Inv...campaign=6912C
There may be other computer related projects that would be easier to start with for example some kind of stand. Different kinds of projects require different tools but the basic hand tools remain pretty much the same.
I am not familiar with Partex. Is it a USA product?
Disclaimer
& Stay Safe
.....Bob
Old 07-09-2009, 10:54 AM   #3
Extreme DIY Homeowner
Scuba_Dave's Avatar
I considered covering my case with wood, but not using wood as the basic case
I was going ot have a door at the front for access to floppy drive/ports/CD/DVD etc
The back I was going to leave pretty much open
Old 07-10-2009, 06:57 PM   #4
analogmusicman's Avatar
you definitely should NOT make a computer case out of wood. those individual parts need a common ground. I've been working on computers for better than 40 years and you can take it from me to stay away from any kind of grounding hasssle.
tnx,
analogmusicman is offline   Reply With Quote
Old 07-10-2009, 11:53 PM   #5
New home owner!
Red Squirrel's Avatar
I've thought of making wood cases but really not sure where I'd find metal motherboard trays. You'd want to at least have a proper motherboard restraint so you can use the standard motherboard standoffs, and also ground it. Wood is a better insulator then metal so you'd want good airflow too, but if you design it then you can easily design it with air flow in mind.
You should see how the dell rack mount servers are made it's quite impressive for air flow.
Old 07-11-2009, 09:44 AM   #6
In way over my head.
Clutchcargo's Avatar
Maybe I'm a tool snob but I don't think you can make an entire computer case using just one tool and the B&D RTX-6 wouldn't be one that I'd consider for a project like that.
If you do decide to make a computer case I'd start with an inexpensive one and strip it down to the chassis and use that as a starting point.
You'll never be sorry you bought the best.
Clutchcargo is offline   Reply With Quote
More On This Topic
So, I want to say a little bit about letter tools which are single action tools and then we'll move on to the double action tools. A lot of people like to put names on their leather projects or maybe even write like a little slogan on there, I don't know... Read More »
A scissor jack is a primary tool used when changing motorcycle tires; learn how to use one in this video on DIY motorcycle maintenance for flat tires. Read More »
You should select furniture making plans primarily on your skill level. Plans that are too complex or which require special equipment may only serve to frustrate you. Fortunately, furniture making plans and furniture "how-to" articles are widely... Read More »
Another reason you might need holes will be if you have several pieces of leather you're going to assemble into a project. This is a knife sheath kind of project here. There are holes in it where your stitching lines goes through. A lot of wallet... Read More »
On behalf of Expert Village.com my name is Don with Friendly Computers and I'm here today to tell you a little about power supplies. So we moved the cameras back into our shop where we do most bench repairs. Now the first thing is if your computer has... Read More »
Can anyone help a newbie? - Help with making a book case cosmicmeeting Carpentry 8 09-10-2008 01:47 AM
hardwood flooring boards matjone Flooring 4 02-01-2008 07:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
