Make Room For Over The Oven Microwave - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-14-2011, 08:01 AM   #16
Originally Posted by mrgins View Post
My mistake. I thought the OP was installing a regular MW
I am. I'm not putting in a shelf. I'm attching a regular OTR microwave.
gilbo125 is offline   Reply With Quote
Old 02-14-2011, 11:53 AM   #17
OK. So the exhaust venting is assumed. The MW needs to be approx. 18" above the range.
I'd remove the existing cabinet and either cut it down as dtsman suggested, or slide it up to the ceiling if it gives you enough room
mrgins is offline   Reply With Quote
Old 02-14-2011, 12:07 PM   #18
Yea, I wasn't as clear as I should have been initially. Currently we have a microwave sitting on our countertop. We also have a new in box microwave sitting in it's box in the garage. This new microwave is a regular OTR model and will be installed. then the mw on the counter will get donated. So the new mw will have venting. Thanks for the feedback. Looks like I'll be doing some carpentry.
Room Air Purifier - which is best? nhart Appliances 17 07-29-2014 10:00 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Venting of a microwave oven into attic. BobLink General DIY Discussions 2 09-07-2009 05:20 PM
How to make room for humidifier zunk HVAC 3 02-24-2009 06:00 AM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
