Make Room For Over The Oven Microwave - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 01:22 PM   #1
Make Room for Over the Oven Microwave
Any thoughts on how I can make room in the picture below to install an over the oven microwave? As it is now, the microwave would site way too close to the top of the stove.
gilbo125 is offline   Reply With Quote
Old 02-13-2011, 01:38 PM   #2
Carpenter
dtsman's Avatar
Are you wanting to keep the built in cabinets or do you plan on replacing them?
If you are going to keep the built in cabinets, your only options is to remove the cabinet doors, draw a template on the wall to represent where the microwave is go to be, cut the cabinets around the template and then rebuild the lower half of the cabinets to create the notch for the microwave. Those cabinets are usually just 1x2 framing and plywood. Cut the doors to fit the cabinets and paint.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Old 02-13-2011, 01:56 PM   #3
Are you sure you want your microwave over the stove that gives rise to a lot of moisture rising? just a query.
amen2u is offline   Reply With Quote
Old 02-13-2011, 01:57 PM   #4
I plan on keeping the cabinets so I guess that is my only option. Damn older homes and trying to modernize them.
Old 02-13-2011, 01:58 PM   #5
We really have very little counter space. So yes the microwave needs to be relocated over the oven.
Old 02-13-2011, 02:52 PM   #6
Rewards Points: 5,336
You can keep those cabinets, but not over the stove.
They need to be removed. The design is easily duplicated, so build cabinets the correct size and mount them.
Open the wall to the exterior before you mount them as it will be easier to do any needed framing in the wall with them removed.
While you're at it you can build a regular cabinet to fill the space to the right of the stove.
Ron
Old 02-13-2011, 03:23 PM   #7
Aren't 90% of them positioned there anyway?
mrgins is offline   Reply With Quote
Old 02-13-2011, 03:47 PM   #8
And they all have vent fans incorporated into them to disperse said moisture.
You don't place a standard microwave on a shelf, over a stove.
Ron
Old 02-13-2011, 04:52 PM   #9
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
whats the measurement from the back panel on range to the bottom of the cabinet? looks to me as if you may have enough room, an OTR should have 22" minimum from counter top to bottom of cabinet.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 02-13-2011, 05:26 PM   #10
It would be about 3 " or so over the back of the stove.
Ron
Old 02-13-2011, 06:54 PM   #11
Ron is right. Right now the cabinet is about 19.5 inches above the back of the range. Figure the microwave about 16 inches leaves it about 3 inches above the back of the range. Looks like some of the cabinet is gonna have to come out.
Old 02-13-2011, 11:53 PM   #12
#1 HAWKEYE FAN
3" is plenty and actually very common
Old 02-14-2011, 12:16 AM   #13
Rewards Points: 164
I have exact same problem.
I had range hood took it out to put in microwave, and with the cabinets being too tall I have to build a shelf of some sort to place the microwave on or do some sort of stand over range. Between myself and another cant come up with the right idea. Sorry didnt mean to butt into your post but didnt want to post "almost" the same problem maybe we can help eachother...opening size is 36 "wide and 20" to top of rangecontrol panel 29" to top of cooktop. Microwave is 22w X 16d X 12.5h Want something strong enough to hold microwave. Can i secure board to wall joists screw top to it and brace with triangles with brackets underneath?
68MHJCs is offline   Reply With Quote
Old 02-14-2011, 07:23 AM   #14
Rewards Points: 1,216
Move the cabinets up to the ceiling then you should have enough room for the micro to fit.
COLDIRON is offline   Reply With Quote
Old 02-14-2011, 07:57 AM   #15
Ron
My mistake. I thought the OP was installing a regular MW
Room Air Purifier - which is best? nhart Appliances 17 07-29-2014 10:00 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Venting of a microwave oven into attic. BobLink General DIY Discussions 2 09-07-2009 05:20 PM
How to make room for humidifier zunk HVAC 3 02-24-2009 06:00 AM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
