LP Smartside Lap Siding - Nailing Question? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 02:53 AM   #1
Rewards Points: 150
Hello All,
I am looking into using the LP Smartside Lap Siding, first learned about it here on the site and wanted to ask a couple questions.
It appears to me that it goes up some what similar to the Hardie lap siding.
Except the LP has a set distance by the looks of it.
What size nail would you guys use?
Going to be 2 x 4 - 16'' o.c. with 7/16'' structual OSB and then Tyvek then Siding
With the Hardie used a 2 3/8 R.S. HDG Nail - Would you guys recommend the same???
canyonbc is offline   Reply With Quote
Old 01-14-2010, 08:09 PM   #2
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
Originally Posted by canyonbc View Post
Hello All,
Should work perfect. You may already know this, don't bury the nails. It's better to light set the nail and finish with the hammer if need be. It's a durable product, takes a nail real well. The web site offers some installation tips under procedures. You may want to glance through it before you get started. Have fun!
Kevin
Kevin M. is offline   Reply With Quote
Old 01-15-2010, 02:01 AM   #3
Rewards Points: 150
Kevin
Kevin - Thank You!
I will go read it all in all.
Yes, I make an effort to not set the nails in, actually I really make sure they are not sunk and have a helper or someone come behind me and nail them in
I have not read the instruction yet, but with the Hardie I have the siding gauges made by Pac Tool
Do you know if there is anything like this, I am going to look up and see if I can use the same gauge set up
Mike
Old 01-18-2010, 02:26 PM   #4
Rewards Points: 150
Anything you guys have used???
foam back siding vs. reg vinyl siding marnic Building & Construction 3 02-16-2009 08:48 AM
Siding fix it question jackie treehorn Building & Construction 9 01-28-2009 10:46 PM
New siding, paint exsisting siding, or powerwash?? fixiechick General DIY Discussions 5 01-23-2009 12:50 AM
face nailing question.... shawn99 Flooring 3 12-20-2007 09:33 PM
Vinyl Siding & windows question blazermaniac General DIY Discussions 6 04-08-2006 01:47 PM
