Lower Lip On Shelves - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 10:32 PM   #1
Rewards Points: 208
Lower Lip on Shelves
i had a carpenter build me pantry shelves. i asked for 1/2" lip on top and he also added 1.5" lower lip which i didn't want. he says it's for stability. is he right? now i have to turn some bottles sideways to get out because of that lower lip.
Uploaded with ImageShack.us
Scully is offline   Reply With Quote
Old 03-05-2012, 10:42 PM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
It might be stable but it's ugly.
A piece of 1-1/4" with a 3/4 " dado cut through the middle of it will give you a 1/4" lip on the top and the bottom and lots of stability.
tcleve4911 is offline   Reply With Quote
Old 03-07-2012, 07:35 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
It does add stability, but you don't need it to hang down that much. I usually use an 1-1/4 piece and flush it on the top of the shelf, sometimes 1-1/2 depending on the length of the shelf. Your carpenter used 2-3/4" , that's over kill.
Millertyme is offline   Reply With Quote
Old 04-03-2012, 05:58 PM   #4
Haverhill Trade 1965
shelves
Not sure how long the shelves are, or how thick the plywood is, (3/4" is best), but from the picture the plywood is going the wrong way. You need the strength, (and the grain of the majority of the plies), going the length of the shelf. That would have needed less reinforcing.
Duckweather is offline   Reply With Quote
Old 04-03-2012, 08:41 PM   #5
Rewards Points: 208
i originally asked for pine shelves, and the contractor did a switch a roo and gave me the 3/4" plywood instead, saying that it's stronger than pine. i would not hire this company again.
Old 04-03-2012, 08:59 PM   #6
Missouri Bound's Avatar
Me either. It's up to the contractor to provide what you pay for, not whatever he wants. Making suggestions is perfectly normal, but not doing it his way instead of yours. Have him come back and change it or refund your money. If he refuses, spread the word.
Do you want it your way or the right way?
Building Shelves for cat set Carpentry 7 02-29-2012 04:59 PM
DVD shelves above wainscoating? Morgan19 Home Theater 1 10-08-2011 10:40 AM
Pantry Sliding Shelves nicksteel Carpentry 14 05-23-2011 06:07 PM
Cantilever shelves in bathroom pennshaq Remodeling 1 07-11-2010 09:26 PM
Extending pantry shelves info@homeworkbydave.com Carpentry 6 10-24-2008 09:57 PM
