Lots Of 2 Inch Thick Maple To Cut. What Kind Of Tablesaw? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-08-2010, 09:26 PM   #1
Lots of 2 inch thick maple to cut. What kind of tablesaw?
After 7 years of building my shop, and buying close to 15k worth of tools (and the renos), I need to buy a tablesaw. The old Delta that I have just will not cut anything like this, and I need to buy a tablesaw that I will be using for the next few years that will be able to deal with all this 2 inch thick stock that has been aging in my shop the last few years. I need some idea what kinda machine I need to buy that this maple will not be a problem. Can someone steer me? Thanks folks...Kerry
kerryk is offline   Reply With Quote
Old 08-09-2010, 06:01 AM   #2
DIY staff
Rewards Points: 7,174
Get a Grizzly catalog--I've had a 10" cabinet saw from them for several years--
Strong,accurate--fine fence---56"? rip capacity.
Great customer service. I use mine to build cabinets for my business.---Mike---
Old 08-09-2010, 06:26 AM   #3
A cabinet saw would be a good choice, but an expensive one. A less expensive saw with a belt drive(no direct dirve) and a higher HP motor will do the job. But make sure you have a quality carbide blade.
Old 08-09-2010, 06:33 AM   #4
the Musigician
DangerMouse's Avatar
If the motor still runs, just buy a new, good quality blade and you're good to go! Why buy a new one? (Unless you have a small 7" and want a new 10")
DM
Installing Ceramic Tile over thick pine Heggtveit Flooring 3 07-19-2010 09:37 PM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 11:21 AM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
is 0.25 Inch tile thick enough to go on the floor ? amakarevic Flooring 3 05-04-2008 11:22 PM
