Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-21-2010, 11:11 PM   #1
Loose window sill
I moved into a house built in 1950s a few months ago and noticed a window sill is loose. Does it mean something hidden is rotten? And how should I fix it? Please see attached photos. Thanks in advance.
Loose window sill-bottom-view.jpg   Loose window sill-top_view.jpg   Loose window sill-whole-window.jpg
ken123 is offline   Reply With Quote
Old 02-22-2010, 07:20 AM   #2
Loose window sill
From what I can see, it only neans the sill is loose. The sill is usually nailed to the window frame thru the top of the sill. There is nothing structural about the sill trim, it is only trim. But usually caulked where it meets the window frame to reduce drafts.
The Following User Says Thank You to Just Bill For This Useful Post:
ken123 (03-17-2010)
Old 02-22-2010, 07:56 AM   #3
Household Handyman
Loose window sill
I'm a big fan of stained vs. painted wood, especially windows. Look at the piece of trim below the "stool" (the loose piece) to determine where the finish nails were put in. Carefully remove the trim piece. There's probably a small gap there between the drywall and stool. With the room dark, use a flashlight to look into this gap and evaluate any wood which you can see for damages. IF any wood seems to have any damages, proceed as needed. I'm betting there's none. Position the stool where it should be and drive one/maybe two, small (6d finish) nail(s), at a slight angle, through the bottom of the stool into the trim on that side. Get 'em close, use a nail set, to prevent damage. When you removed the bottom trim--did any nails stay with the trim? IF SO--pull the nails through, don't drive them backwards on trim--less face damage. Replace the trim, and hopefully no one, but us, will ever know. David
The Following 2 Users Say Thank You to Thurman For This Useful Post:
ken123 (03-17-2010), Tom Struble (03-17-2010)
Old 02-22-2010, 09:26 AM   #4
Loose window sill
Thanks a lot Just Bill and Thurman! Both of your comments are very helpful.
Old 02-22-2010, 02:59 PM   #5
Loose window sill
All the nails in the picture have a black staining around them that could be rust(i.e. water). I would remove the side trim and look behind to see why. If there's an issue behind the side trim, remove the apron and the sill to see how far it's spread.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
ken123 (03-17-2010)
Old 03-17-2010, 11:00 PM   #6
Loose window sill
I haven't opened the sill yet. I'll post my results after I do
Old 03-17-2010, 11:26 PM   #7
Loose window sill
What you are showing is the window stool. It is just inside trim and they often have some play because of people sitting on them when the window is open and because they are only held in place by a few finish nails..
hayewe farm is offline   Reply With Quote
The Following User Says Thank You to hayewe farm For This Useful Post:
ken123 (03-17-2010)
Old 03-17-2010, 11:42 PM   #8
Tom Struble's Avatar
Loose window sill
ken...just so you know sills are on the outside,stools are inside
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
ken123 (03-17-2010)
Tags
loose, window sills
Replacement window sill almostgreen Carpentry 1 10-11-2009 07:44 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Crooked window sill in old wood house bofusmosby Carpentry 36 04-13-2009 09:34 PM
sill angle problem replacement window drewhart Building & Construction 1 10-30-2008 10:56 PM
strange brown spot on window sill ugabulldog Building & Construction 9 05-18-2008 09:38 PM
