Loose Hinges - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 10:20 AM   #1
Rewards Points: 37
loose hinges
Hello,
Recently replaced 1960's hollow core doors with solid oak veneer doors. The old doors only had 2 hinges and the installer used only two hinges as well.
Guess what, the hinges are loose and I can't tighten them. Should I install longer screws or bigger screws?
Is there anything I can plug the holes with? I have tried using small pieces of wood to make the screws tight, but that only works for a few opening/ closings then loose again.
Thanks for any advice.
nbmech is offline   Reply With Quote
Old 02-21-2012, 10:55 AM   #2
Rewards Points: 77
Plugging the holes with oak slivers and glue is what I would first do. After that I would go with at least 2" or 2 1/2" screws. It is hard to find brass screws and I hate them anyway, so I spray paint the heads of drywall or deck screws to the hinge color and use them. I usually drill a pilot hole so the screw will go in without tearing up the head. This will anchor the hinge and door jamb to the stud. Just be careful not to drive in the screw too tight or it will shift the door and jamb. I would plug the holes and use short screws on the holes near the pin and only use one long screw in one of the holes near the edge of the hinge. Those holes are sure to hit a stud. The others have a chance of hitting drywall. It is important for a solid core door to put at least one long screw in the top hinge to anchor everything to the stud. Gravity becomes a big factor with an 80 lb. door. A long screw in the bottom hinge will help stabilize the racking effect when the weight of the door is hanging in the open position.
MNsawyergp is offline   Reply With Quote
Old 02-21-2012, 11:19 AM   #3
There are also 1/4" dia. x 1/2" lg metal threaded inserts that have a very coarse thread on the outside and a machine screw thread on the inside. They grab a lot more wood so they should resist pullout forces better.
Old 02-21-2012, 03:03 PM   #4
Rewards Points: 77
Those inserts won't work very well in door jambs that are particle board core. The big threads will just tear out the particle board. That's why the screws are loose in the first place.
The Following User Says Thank You to MNsawyergp For This Useful Post:
woodworkbykirk (02-21-2012)
Old 02-21-2012, 06:38 PM   #5
recently retired
Rewards Points: 280
Are we assuming that the hinges are pulling loose from just the jambs and not the doors as well?
Are the hinges rated for that load and did the doors come pre-mortised?
Are the right size screws being used or did someone just use what they had?
If everything else is correct you can take hardwood dowel and a corresponding drill bit and drill out the screw holes and insert pieces of dowel, then using a Vix bit drill new holes.
Keith Mathewson is offline   Reply With Quote
Old 02-21-2012, 07:00 PM   #6
Rewards Points: 14,312
If it's the screws in the jambs just use the same gauge screw just far longer. Far less work and will work 100 % of the time.
He should have added an extra hindge for a heaver door.
No cheap insert is going to work.
You never want to use a bigger diam. screw, It will not sit flush with the counter sink in the hindge and may stop the door from closing.
Old 02-22-2012, 12:56 PM   #7
Making a jamb out of particle board is asking for trouble.
I'd try to use these somehow but you'll have to remove the casing.
http://www.google.com/search?client=...Hcre0QG866yWBA
Old 02-22-2012, 01:35 PM   #8
Rewards Points: 1,770
Longer screws might be worth it a try but may not work since the wood frame perimeter of the door isn't too wide. Fill the holes with dowels otherwise as described previously.
bob22 is offline   Reply With Quote
Old 02-22-2012, 02:43 PM   #9
Grainger sells very long skinny drill bits.
Get any 0.032" dia. stiff metal rod, drill a perfectly aligned hole through the jamb and through the screw, use the rod as a sort of anti-rotation cotter pin, caulk the jamb hole.
Old 02-23-2012, 02:51 AM   #10
Yes you can fill the holes, longer screws should work well also, just make sure not to pull the doorframe out of whack.
Always a good idea to add a middle hinge as well when going from a hollow to solid core door.
chrisBC is offline   Reply With Quote
European Hinges for Curved Kitchen Cabinets thiftyspender Carpentry 2 04-20-2016 08:00 AM
Space for hinges on custom closet doors nrk411 Carpentry 3 07-11-2010 07:34 PM
Blum hinges from 15 years ago?? MI-Roger Carpentry 14 02-23-2010 12:44 PM
Cabinet hinges don't fit... arghhhh!!! pisces7378 General DIY Discussions 7 12-25-2009 07:47 PM
help, loose door hinges screws clyde Carpentry 13 12-19-2007 01:31 PM
