-   -   Looking for good hinge/arms (http://www.diychatroom.com/f14/looking-good-hinge-arms-172031/)
ssgtjoenunez 02-15-2013 08:09 PM
2 Attachment(s)
So I'm not even sure what you call these things but here goes.
I built a custom low profile desk in the office of my laundromat. The office is very narrow so space is at a premium. The idea is to close the desk up when not in use to save space.
I got some folding "arms" to lock the door open when its down. First they are too small and don't reach out into the table top enough. This causes the table top to wiggle and appear unstable. Second they are the fold out kind and have to be locked open and unlocked to close the desk. It's cumbersome at best.
I'm looking for some help finding better options. I've thought of the gas style shocks (for lack of their correct name) that would also help close it when it is being pushed shut.
Basically I'm hoping someone here can help me so I can 1) stabilize the table top and 2) find a better opening and closing mechanism.
I've got more pictures if that would help.
Thanks in advance!
joecaption 02-15-2013 08:21 PM
How thick is it?
I think I would use a piano hinge for one thing.
A simple cheap fix would be to use two pieces of chain that are attached out toward end of the door. Like on a tail gate on a truck.
TarheelTerp 02-15-2013 08:22 PM
Go in the other direction.
1) Make that "table" into a security cover that will hinge UP instead.
2) Make a heavier table that hinges from underneath the box...
maybe with another stick to prop against the wall for stability.
ssgtjoenunez 02-15-2013 08:22 PM
The table top is 1/2"
I'm thinking of replacing it with 5/8" for added stability.
ssgtjoenunez 02-15-2013 08:24 PM
Space is an issue already so this really provides the best possible solution. I'm pretty comfortable with the design, just looking for some ideas on how to open/close better while stabilizing the table top.
joecaption 02-15-2013 08:26 PM
1/2" is to thin, it needed to be 3/4"
ssgtjoenunez 02-15-2013 08:29 PM
Do you think that alone will solve the stability issues? Also any ideas on a better open/close mechanism?
chitownken 02-16-2013 09:37 AM
You can find more hardware options at www.rockler.com or www.woodworkersupply.com
ssgtjoenunez 02-16-2013 12:59 PM
Man this was exactly what I was looking for! I ordered two pneumatic lifts that will eliminate the need for a hasp to hold the cabinet shut.
I also took someone else's advice and purchased a piano hinge as well.
I'm also taking someone else's advice and replacing the table top with 3/4" vice the 1/2" thats there now.
I have to take the front panel and hardware off anyway to paint the unit so I'll tear it down, paint it and then install the new hardware for a finished product.
I'll post some pictures of it when its all said and done.
Thanks everyone for the expert advice!
joecaption 02-16-2013 01:49 PM
I'm not seeing how a pneumatic lift is going to do you any good.
It would have to hindge from the top to make it work.
Picture a truck cap. (topper) It holds the door open.
For that door to stay closed on it's own the box should have been built so the sides were at an angle. And the bottom wider then the top.
ssgtjoenunez 02-16-2013 02:06 PM
The lifts I bought can be applied for doors that open up and those that open down. I bought two, one for each side. They can be set to hold the door open and to assist on the close. A hasp might be needed still but I'm hoping not. Either way I've got to take down the hardware to paint anyway so I can put the new hardware on and see which I like better. I'm already replacing the table top so I can experiment with the current table top with screwing this and making holes to figure out how I want it to look.
ssgtjoenunez 02-19-2013 11:26 AM
3 Attachment(s)
Here's an update for everyone.
ssgtjoenunez 02-19-2013 11:28 AM
So the new hardware should arrive tomorrow. I'm going to stop and pickup the new table top (3/4") today and paint it so that all that remains is to put the piano hinge in place and add the lifts.
Hoping to be done by Friday.
Thanks for all your help everyone!
