Logistics Of Coffering An Existing Ceiling - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-04-2011, 04:15 AM   #1
Thadius856's Avatar
Rewards Points: 504
Logistics of Coffering an Existing Ceiling
I've been working on new bead board wainscoting, chair rail, casing and base boards. Along the way, I picked up some crown, but before it got installed I decided that I want to coffer the ceiling. This obviously presents some problems because the layout I want doesn't line up with the joists.
My plan is to add some extra support from above via the unfinished, un-catwalked attic so that I can bolt the 2x4 base of the coffers against the drywall. Oh boy, I can't wait!
Would it be acceptable to fasten 2x4s on-face to the top sides of the joists and then use glue and long bolts through the drywall? Or must I add 24" blocks between the existing joists?
Also, is green fir acceptable in this application?
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 11-04-2011, 07:52 PM   #2
Thadius856's Avatar
Rewards Points: 504
Bump.
Surely somebody has to have ideas.
Old 11-05-2011, 10:11 PM   #3
Rewards Points: 5,336
Have a structural engineer over to the house to review the plan.
Ron
B. Franklin 1759
Old 11-05-2011, 10:59 PM   #4
You can fasten the 2 x 4 to the joists above using lag bolts. There should not be a need to add additional support considering the joists are currently holding up your ceiling. You can add 2 x 4's from above as a cross section to meet your layout A coffer will not add that much weight to the ceiling. Fastening it using 3 " wood screws would be enough also. Hope that helps.
Kader516 is offline   Reply With Quote
Old 11-06-2011, 08:39 AM   #5
journeyman carpenter
woodworkbykirk's Avatar
why would a engineer be needed for this... hes not building something structural.. a coffered ceiling is nothing more than building a soffit grid system so to create some nice lines in the space
you could use 2 1/2" steel stud, its nice and light weight,, only thing is when you go to hang the crown you can only shoot to the drywall. unless your willing to buy a 15 gauge nailer and the new senco barbed nails for steel stud
woodworkbykirk is offline   Reply With Quote
Old 11-06-2011, 09:04 AM   #6
Sounds like he's removing the current ceiling joist structure and creating a recess in the center.
If he's just adding a soffit around the perimeter, then an engineer isn't needed.
Ron
B. Franklin 1759
Old 11-06-2011, 09:27 PM   #7
Thadius856's Avatar
Rewards Points: 504
Negative on all accounts. I wasn't very clear.
I have an existing ceiling - drywalled, painted and textured. I'd like to coffer it by installing a series of 2x4 base with 1x4 sides. The difficulty I'm having is in attaching it to the ceiling.
The 2x4 grid I want the design to be doesn't line up wight the existing joists. I don't want to remove anything. Since I have crawlspace access, I figured I could add 22.5" blocks between the 24" OC joists where needed... not for structural weight-bearing support just rather just for a place to attach the coffer base.
But the thought of block out each. individual. joist. multiple time. sounds like a weekend of Hell with nothing to show for it (and that's if I don't screw up the drywall while toe-nailing!). I figured maybe I could just throw some full length 2x4, nail them to the top-side of the joists and use longer bolts.
Ideas?
Old 11-07-2011, 02:33 PM   #8
Thadius856's Avatar
Rewards Points: 504
Here's a picture of the coffer frame design I plan to suspend from the ceiling, once I can figure out the support method. (Note: it's up-side-down in the image).
Old 11-07-2011, 04:47 PM   #9
whoa thats gonna be a ton of material going up.. i would be more prone to install a nailer to the ceiling and then hang mdf off of it which creates the beams for the ceiling
Old 11-07-2011, 05:55 PM   #10
Thadius856's Avatar
Rewards Points: 504
Yup. A fair amount of material. More if I decide to panel behind it.
I don't have to run the 2x4s full length, but it would sure make things a lot easier.
Old 11-07-2011, 07:39 PM   #11
yea i agree, can't you lighten up your design. maybe some rips of plywood?????
framingrailman is offline   Reply With Quote
Old 11-07-2011, 08:57 PM   #12
Thadius856's Avatar
Rewards Points: 504
Both MDF and most ply weigh more than the dried pine pictured.
Not seeing the weight savings.
Old 11-08-2011, 04:55 AM   #13
Thadius856's Avatar
Rewards Points: 504
The crown I purchased is 3-1/16" tall when installed to manufacturer specs. I might be able to forego the side pieces entirely and fingernail the bottom 1x back 1/16".
That would remove two 1x4s while shortening the coffer 7/16" and narrowing it 1". The main problem would be finding a reasonable way to nail it all together.
Old 11-08-2011, 07:46 AM   #14
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Your idea of the continuous 2x4's is good
Get those up there and be done with it. Don't worry that you don't have anything to show for it. You will.
I wouldn't eliminate the "fascia" sides. The look of the beam will be awkward.
Take your time.....do it right
tcleve4911 is offline   Reply With Quote
The Following User Says Thank You to tcleve4911 For This Useful Post:
Kent Whitten (11-19-2011)
Old 11-08-2011, 09:37 PM   #15
Thadius856's Avatar
Rewards Points: 504
That's beautiful, and exactly what I want it to look like.
Was that one 2x4 and 1x3?
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
How to wire a 2-prong lamp to a ceiling mount with an existing ground cyantific Electrical 1 08-19-2008 06:22 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 12:16 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Drywall over existing ceiling? billybarty Carpentry 1 03-08-2008 12:05 AM
