Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-29-2009, 04:34 PM   #1
Default Loft (Beam Span)
I'm planning on putting up a storage loft in my garage. It will be over the garage door and then run down the side of the garage in an "L" shape. Well that is the desire anyway. I'm on a crawl space so I'd like to utilize the wasted space above the garage door for storage. I already use some for my Jeep Hard Top that I have on an electric winch.
Have seen several designs on the internet and intend to draw from different ones.
Am staying away from attaching to the ceiling joists as I don't want to add to the load that the roof already has on them. (Have been reading some of the posts on here) and on the net.
This is similar to what I have planned, but I will have to modify it some do to the fact that the right side of my garage door track is bolted to the wall so I can't use a post at the front edge.
The dimentions are roughly 4 or 5 ft deep over the garage door and 18 ft wide. The leg that comes back from there is another 10 feet or so, need to get measurements on that. Have not desided on how wide that portion is going to be, could utilize a full sheet of plywood and stick it out to 8 ft.
http://www.loftysolutions.biz/Garage%20lofts.htm
So thinking of a 6x6 at the two corners on the left and the front right and then again on the very back "L" leg.
Ledger boards along all three walls, not sure if a 2x4 will work for this or if I need to go with a 2x6 laged to the studs. (yes sheet rocked in the garage)
I don't want to be worried about putting weight up here, but there is no more than 4 ft of height up there.
The issue is how to attach the beam on the right side? I had planned to put it on a 6x6 until I took a closer look in the garage and realized the track issue. Don't think putting it on the ledger will work, then I lose another 6".
I'll come back to this issue with a picture or two.
If I could put it on a 6x6, could say 2 2x10's work as a truss? Or do I need to go with something stronger? Not my area at all so I'm looking some help here. Ask away and I'll try to answer your questions.
Thanks!
Mike
kobis is offline   Reply With Quote
Old 10-29-2009, 08:30 PM   #2
Took some measurements when I got home tonight.
Span is 18' 9" wide and from the front of the garage to where the rear posts will go it is 16'.
Garage ceiling is 11' 6" and the top of the opener is 8' 3". Only 38" of space above the garage door, not as much as I had originally anticipated.
In the front right corner theree is a cut out for the hot water heater. It is up on a box. This space is 35" wide from the front of the garage. This is where the I was going to place the front right 6x6. Was thinking of placing an additional 6x6 at the front of this area and run the span beam at 33" vice 48". Then only have the front section go 48" and supports for the overhang area. Would get the section supported on all 4 corners.
More to follow . . .
Old 10-29-2009, 11:43 PM   #3
I went to the web site posted and did some figures: They said in the third example of 20' span with appears to be 2-2x8's = 3000# ---- actually the fiber bending rating on 2-2x8's Doug/fir species with a 20' span is 840# total load. Or 19# per square foot for 1/2 the 4'4" span. How they came up with the number they did, I don't know. 2-2x10's rated at 1366# = 31#sf. The other 1/2 span close to the walls could take a lot more to add up to the 3k total, if the lag bolts were rated by an engineer. This would only be on the 2x10's, though.
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
More On This Topic
Designing a Gazebo's Height
Designing a Gazebo's Height by Expert Village
Hi! Welcome back to Expert Village. My name is Charlies Folkman and today we are going to continue building our gazebo. Now one thing to consider when designing our gazebo is the height. Now usually you want the inside height to be 2 feet taller than the... Read More »
Hello! This is Ross on behalf of expertvillage.com. Would you look at that… someone left the garage door open. Honey! You know, this electronic stuff is pretty easy. Can you get someone to close the garage door please… Read More »
On behalf of Expert Village, my name is George Engle with Mr. Fix-It Handyman here in Miami, Florida and today I am going to be showing you how to install weather stripping on the exterior of your garage door. Okay, we have our garage door closed and we... Read More »
Hello! This is Ross on behalf of expertvillage.com. That is my kitchen door and it is dark outside, it really doesn’t matter I cannot see the garage door anyhow if it was light out because it is blocked by the wall here. I did have to get up to... Read More »
Caring for your garage door can help you save money in the long run. By periodically doing some simple maintenance work, you can avoid serious problems with your garage door and having to spend large sums of money to replace or fix the problem. Here are... Read More »
What size beam to support loft with 16' between supports paperman Building & Construction 3 10-06-2009 07:40 PM
attaching garage loft support to 12 inch steel I beam lospinoj Building & Construction 4 09-14-2009 03:38 PM
Patio Roof Beam Span slakfu Building & Construction 4 06-04-2009 12:45 AM
OSB Stronger than Plywood? Weathermaker01 Flooring 11 07-13-2008 11:04 PM
Remove Load Bearing Wall Beneath Hanging Beam cnaildrivenail Remodeling 0 04-29-2008 01:06 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
