Lock Replacement Non-standard Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 05:34 PM   #1
The lock on my entrance door is broken. I bought a new lock set, only to discover the door is a non-standard size (thinner) and the new set won't fit. Anyone know where I might find a non-standard lock (locking doorknob and dead bolt) to fit the door? Thank you!
jane99 is offline   Reply With Quote
Old 04-19-2011, 09:08 PM   #2
recently retired
Rewards Points: 280
Most locksets will fit an exterior door or an interior door, how thin is your door?
Keith Mathewson is offline   Reply With Quote
Old 04-19-2011, 11:11 PM   #3
Rewards Points: 5,336
Interior doors are 1 3/8" thick. Exterior doors are 1 3/4" thick. There are variations ,but it's not really important at this point in the relationship.
Ron
Old 04-20-2011, 08:38 PM   #4
Hmmm . . . the door is 1 and 3/4" thick . . . the contractor's guy said the lock was defective and that I needed to return it. Then, the contractor told me no, that it isn't defective, but it isn't the size for my (supposedly) non-standard door and they might have to use a spacer. Sounds to me that the door is standard, so not sure what gives. Guess I'll have to take a second look at the lock set and see what size IT is . . .
Old 04-20-2011, 08:49 PM   #5
If it's an exterior lock you have and a regular exterior door, my guess would be the contractor.
Who manufacturer's the lock. Some high end locks are a tricky install if you're not familiar with them or you can't follow directions.
Ron
Old 04-20-2011, 09:20 PM   #6
recently retired
Rewards Points: 280
1 3/4" is the standard for an exterior door. Ron is likely correct in his post. The only other thing I can think of is that the offset may be non-standard but it likely came pre-bored.
Old 04-20-2011, 11:37 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,030
Could they be talking about the backset of the lock?
Backset - The backset is the distance from the edge of the door to the center of the 2-1/8" bore hole. In the U.S. there are two common backsets for residential locks, 2-3/8" and 2-3/4".
Many (but not all) come with an adjustable latch that will accommodate either backset. If the backset of the new lock is not adjustable you may have to a different latch.
Coastal South Carolina
Old 05-08-2011, 08:49 PM   #8
I agree with rjniles, most locksets now come with adjustable backset. door thickness should be okay. If your door was thinner than 1 3/8" you would most likely need spacers.
henrybo is offline   Reply With Quote
Installing simple lock on a hollow metal door? heartj00 Building & Construction 10 11-29-2010 01:17 AM
Keyless Door Lock? PaliBob Building & Construction 3 04-11-2010 02:16 PM
had to break down a door, how to repair splintered wood around lock area? mxyplizk Carpentry 17 06-09-2009 09:42 AM
