Loading Nails In Nail Gun - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-03-2014, 06:40 AM   #1
Rewards Points: 874
Loading nails in nail gun
Bought a new Porter Cable compressor and it came with a nail gun and some nails. I read the instructions but still can't figure out how to put the nails in ...lol.
Mstrlucky74 is offline   Reply With Quote
Old 02-03-2014, 06:49 AM   #2
Rewards Points: 34
If it's a finish nailer, there should be a lever on the side that slides back and locks. The nails drop into a channel on the top. Pics or a model# would help.
Dan
djlandkpl is offline   Reply With Quote
Old 02-03-2014, 07:13 AM   #3
Post a picture of the gun!
Their will either be a spring loaded release on the side or the nails will be loaded through the rear and you'll pull back a follower to keep forward pressure on the strip of nails.
jponto07 is offline   Reply With Quote
Old 02-03-2014, 07:58 AM   #4
Gymschu's Avatar
Rewards Points: 846
I had the same problem with my first nail gun.
Old 02-03-2014, 08:02 AM   #5
Rewards Points: 13,748
I have to stop and think every time I use my narrow crown gun, you have to flip it over and load up side down which is different then all my other guns.
Old 02-03-2014, 08:15 AM   #6
True. I forgot about that type.
Old 02-03-2014, 08:32 AM   #7
I show up on a simple job I had a new guy that had told me he was a framer was working on.
He had one of my framing guns all apart and said it would not shoot.
It was a 20 deg. angle nailer and he had the nails in backwards.
I hand him my Paslode so he could get back to work and he loads the gas bottle that says right on the bottle for finish nailers only, (same size bottle, different color) then complains that one will not shoot.
Turned out to be a short day for him. Wonder where he's screwing up now?
Gymschu (02-03-2014)
Old 02-03-2014, 08:40 AM   #8
Rewards Points: 3,839
I had zero problems with the first 2 or 3 as they loaded like a stapler. Then I bought a Senco finish nailer and it took a bit effort to figure out. I still have to think about to remove the nails to changes sizes.
Colbyt is offline   Reply With Quote
Old 02-03-2014, 09:25 AM   #9
Rewards Points: 874
Here you go. I just don't know which way to install them. Thanks
Old 02-03-2014, 11:22 AM   #10
The nails will load from the Top of the magazine on the gun. First pull the follower toward the rear of the gun until it locks. Then drop some nails into the exposed slot on the top of the magazine, pointed side down. Finally, there will be a release in the rear of the gun to snap the follower forward.
All of this should be spelled out in the owners manual, btw.
Old 02-03-2014, 05:44 PM   #11
General Contractor
Gary Evans's Avatar
What are you using it for ?
Gary Evans is offline   Reply With Quote
removing nails from unsealed shingles (made a mistake but the weather is cold...) jkbrennan Roofing/Siding 7 11-14-2013 06:07 PM
Used the wrong nails. ndmeier Remodeling 10 02-18-2012 10:42 PM
nails for treated lumber-do they make those for nail guns?? 4just1don General DIY Discussions 5 07-22-2009 09:23 PM
Best Practices for Framing Nail size jms5883 Remodeling 7 01-31-2008 11:37 AM
Coiled roofing nails for nail gun twaters12 Roofing/Siding 3 02-06-2006 07:37 PM
