Load Bearing Wall Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-24-2011, 02:57 PM   #1
I have what appears to be a load bearing wall in my basement. It is on one side of my basement stairwell and sits directly below a double floor joist. This floor joist however is also supported on one end by the concrete foundation wall and by a know load bearing wall on the other end. The wall in question has double top plate as well. Above this is the main level stair well, which is positioned in the same orientation of as the basement stair. I'm only looking to remove about a 1/3 of the wall to open upon the stair to my basement. Does anyone see an issue with this? Thanks!
thedudeabides! is offline   Reply With Quote
Old 10-24-2011, 03:58 PM   #2
Rewards Points: 1,578
send a picture or two or three,
How to post a picture:
How to attach a photo to a post
bob22 is offline   Reply With Quote
Old 10-24-2011, 04:53 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,112
theres a good chance a engineer should be consulted, if the wall is bearing its supporting the double joist for the stairwall opening but also the wall that supports the stringers for the main floor stairwell.. without seeing it though cant really judge it properly
woodworkbykirk is offline   Reply With Quote
Old 10-24-2011, 09:27 PM   #4
Rewards Points: 5,336
The staircase framing will usually be enough to support the loads. The walls can then be removed without issue.
Checking this would be a good idea in case additional loads were applied.
Ron
B. Franklin 1759
Old 10-25-2011, 04:45 PM   #5
Thanks for the input guys. See picture. I'm plan on removing studs #1-3 in the picture. However I'm effectivly only removing 2 studs as stud #3 is not even touching the top plate.
Old 10-25-2011, 06:01 PM   #6
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,340
It doesn't look like a bearing wall to me. If in doubt, you could just throw a header in the wall.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
The Following User Says Thank You to Clutchcargo For This Useful Post:
Ron6519 (10-25-2011)
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 05:35 PM
Passthru in Load Bearing Wall - Graphic Included Evil Scotsman Building & Construction 13 11-08-2010 02:07 PM
Load Bearing Exterior wall however it has an overhanging porch rhoton1 Building & Construction 2 03-16-2009 06:19 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
