Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-29-2009, 02:09 PM   #1
Default Load bearing wall and joist hanger
Can I use a beam with joist hangers to support the joists in a 4ft opening of a load bearing wall? I have little height clearance due to different floor levels between roooms
cabphillips is offline   Reply With Quote
Old 10-29-2009, 03:09 PM   #2
In way over my head.
Clutchcargo's Avatar
Yes, that's what you do when you want to tuck a beam into the ceiling.
You'll never be sorry you bought the best.
Clutchcargo is offline   Reply With Quote
Old 10-29-2009, 04:02 PM   #3
Be sure to add blocking in the floor to bearing below for the new concentrated point loads or run the header 16" long each way over the walls.
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
Old 10-29-2009, 07:48 PM   #4
Remodeling Contractor
Check with an engineer or architect first.
You can't just throw in a beam and some hangers in an opening and call it good. In this situation, each end of the beam now has a point load or concentrated load. This load has to be carried down to it's own footing.
For example, if this is in a second story, the beam would have to be supported by trimmer studs (also called jack studs), then a bearing point through the floor joist system, then a bearing point in the first floor wall, then another bearing point in the first floor joist system, then a bearing point through a basement wall to a footing in the basement floor.
Failure to properly carry bearing points can cause structural damage to your home.
eisert is offline   Reply With Quote
Old 10-30-2009, 05:33 PM   #5
Building codes guy, Mod
thekctermite's Avatar
Well said, couldn't agree more. Even if the proposed scenario is structurally feasible, there are a multitide of hangers that could be utilized. Using the incorrect hanger for the imposed loads would be bad...Best to have it professionally sized.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
More On This Topic
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When you're framing your basement by yourself, or if you've hired someone else to do it, one thing to think about is the spacing that you will use to space... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. However most of the building material that I will be using until I get the stud walls up and a exterior wall up and a roof over it could be expose to some weather without any... Read More »
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
This is Rob McMahon with ExpertVillage. Now, with a framing gun, there is generally two different, two different types of nailing styles that you use. One is through nailing which is preferable in most situations because it gives you the most strength... Read More »
Hi this is Drew Finn for expertvillage.com we are going to talk about cleaning and maintaining a deck. This video is presented by Black Dog Video and you can visit us on the web on blackdogvideo.biz. When we are checking underneath we want to make sure... Read More »
Sister joist and load bearing wall Daniel048225 Building & Construction 2 09-21-2009 11:33 PM
Load bearing wall removal options ikessky Remodeling 2 08-24-2009 05:18 PM
Exterior Load Bearing Wall Parallel to Joists samjack Building & Construction 4 08-02-2008 10:37 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 11:11 PM
Load Bearing Wall or not?? dtmbizzle Building & Construction 3 07-16-2007 09:12 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
