-   -   Load Bearing Wall? (http://www.diychatroom.com/f14/load-bearing-wall-91852/)
robthebuilder 01-10-2011 12:05 AM
Load Bearing Wall?
I have a 2 Story House and I am finishing the basement. At the bottom of the stairs, there are walls on both sides that I would like to cut back one foot. One one side, there is nothing resting on top of the double 2 x 6 in the last one foot. The item that is one foot back is a floor joist that does span all the way to the main beam in the middle of the basement. On the other side, it is a similar case with nothing resting on top of the last foot, but there is a metal strap that extends up to a block that was installed between two floor joist. My question is, can I remove the last foot and double the 2x6 under the last truss?
epson 01-10-2011 12:10 AM
Call a structural engineer to assess your situation every wall effects something in the home.
TheDoorGuy 01-10-2011 08:15 AM
I tend to agree with epson but if you post a picture or two it might help with the assessment.
mrgins 01-10-2011 12:12 PM
What is directly above the one foot of wall?
robthebuilder 01-10-2011 01:56 PM
1 Attachment(s)
hopefully this helps
robthebuilder 01-10-2011 01:58 PM
Nothing on one side of the stairs, the other side has a metal strap that extends up to a 2x 12 that is nailed between two trusses.
robthebuilder 01-10-2011 01:59 PM
pictures
1 Attachment(s)
Here are some pictures
CplDevilDog 01-11-2011 07:13 AM
That section of the wall does not appear to be carrying any load.
mrgins 01-11-2011 08:21 AM
Never seen a steel strap holding up a wall before. Have an engineer look at it
