Load Bearing Wall??? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-14-2011, 03:53 PM   #1
kj1
I have a split level home. The main level has an interior wall which runs parallel to the floor joists. Above this room are trusses which are supported on the exterior walls. The trusses span 36 feet. Could there be a center load on this wall?
kj1 is offline   Reply With Quote
Old 05-14-2011, 10:51 PM   #2
Registered User
Rewards Points: 4,936
Yes, possibly.... an attic picture would help identify a point load on the truss with a label, ink stamp or web chord.
Welcome to the forum!
Gary
Old 05-15-2011, 07:46 AM   #3
Generally, trusses do not require center support, but as suggested, a pic of the truss design would help. And the wall does not seem to have support under. A load bearing wall will have support under in the form of double joists, beam, etc. My guess is not load bearing.
Old 05-28-2011, 07:16 PM   #4
I have a similar issue.
Here are some pictures. The wall I took out runs parallel to the trusses.
I would like to extend the opening from the kitchen.
I would also like to shorten the red wall that separates the hallway from the living room.
Any help or recommendations would be greatly appreciated. thanks.
sknobs is offline   Reply With Quote
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 06:35 PM
Nasty Load bearing wall with twisted studs, and crown issues rob_chalk Remodeling 4 08-24-2010 09:27 AM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 01:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 07:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
