Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 05-03-2011, 07:11 AM   #1
GBunny
Load bearing wall
A couple of studs under the basements stairs were removed when I bought house. One of the studs is under a wall. Is that considered a load bearing wall. If so, what do we need to do to support it?
GBunny is offline   Reply With Quote
Old 05-03-2011, 09:32 AM   #2
I have gas!
Clutchcargo's Avatar
Load bearing wall
Your really not going to get much response with such a vague description. Got a picture?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 05-08-2011, 08:51 PM   #3
Load bearing wall
sounds like you need a header, but can't say for sure without looking at it. how many studs, what is the floor underneath it, etc.
chrisBC is offline   Reply With Quote
Old 05-08-2011, 09:33 PM   #4
Super Moderator
Load bearing wall
We need a picture----That was setting on the basement floor? I doubt if it was load bearing.
Can't tell from your description.---Mike---
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 06:35 PM
Nasty Load bearing wall with twisted studs, and crown issues rob_chalk Remodeling 4 08-24-2010 09:27 AM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 01:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 07:45 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
