Leveling Multiple Doors Trim? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-24-2010, 12:45 AM   #1
Leveling multiple doors trim?
I'm installing new molding in my bedroom, and when I started installing the door trim I realized that the the tops of the three doors were not level.
The doors are all in a row on one wall, and the trim that I am installing is going to be pretty complex, with crown type molding on top, not standard colonial case molding (similar to this- http://picsicio.us/image/a8243275/)
So i thought it might look funny with with a 1/4" reveal around and the top trim at different levels and angles.
If i instead put all of the trim at the same height the reveals on the top will be different sizes, which would probably also be noticeable.
Is there a way to install the molding so that it will not look bad?
brodieb666 is offline   Reply With Quote
Old 11-24-2010, 07:14 AM   #2
Tops were not level, of not in line with each other??? If not level, make the trim fit the opening. Installing level trim to an unlevel opening looks bad. Or fix the openings first.
Old 11-24-2010, 11:25 AM   #3
The doors are all uneven with one another, and two of them are out of level.
To fix the openings would i need to remove and replace the jambs?
Old 11-24-2010, 12:33 PM   #4
jlhaslip's Avatar
Rewards Points: 994
Are they all passage doors? or is there a bi-fold in the mix? Seems to me the rough openings are different heights for bi-folds.
Very likely you will need to remove and re-install those doors. Set a level mark on the wall and install to that height.
Do you plan on one head casing for all three doors? or individual head casings?
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 11-24-2010, 01:06 PM   #5
Yes, they are all passage doors (entrance, closet, bathroom), and I was planning on separate head casings although two of the doors are close enough that the trim will come pretty close to touching.
Redoing the doors is what I was hoping not to have to do... .
Old 11-24-2010, 09:02 PM   #6
DIY staff
Rewards Points: 7,174
Trim the 2x6 trim board so the reveal and the top height are the same---
No one is going to notice that one is a bit narrower than the other--
Old 11-24-2010, 09:54 PM   #7
recently retired
Rewards Points: 280
If the door jambs are not the same height the parting bead will be at different levels. Adjusting the frieze board will make the cornice tops the same but you will still see a difference at the parting bead. If the look is important to you, you will have to reset some of the doors.
Keith Mathewson is offline   Reply With Quote
Old 11-26-2010, 06:31 PM   #8
How far off are they? Sounds like you need to re-install a couple of doors to plumb them up anyway
mrgins is offline   Reply With Quote
Old 11-28-2010, 09:23 PM   #9
Well i guess that i have to fix them, but all of the doors were plumb.
The greatest difference between doors was about 1 inch, and the greatest slope in one door was 7/16ths over 2'.
Old 11-29-2010, 08:14 AM   #10
Then you need to go from the lowest point and level across, cutting the frames to height. If your doors are raised panel, you also need to be careful to match up the horizontal members of each door, and the hinges
Old 12-03-2010, 05:29 PM   #11
? Where is it?
jasonsmithbuild is offline   Reply With Quote
Old 12-08-2010, 01:35 AM   #12
Break up the pattern
Think about using a different casing size on the center door, this will break up the line and make any differences much less noticeable.
rapidfit is offline   Reply With Quote
Tags
door casing , level , molding , trim
Sliding Closet Doors & Base Trim HangGlide Carpentry 4 03-26-2010 11:09 AM
Do Floor Installers Usually NOT Trim Doors? thebigsee Flooring 20 11-22-2009 10:14 AM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 01:16 PM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 11:16 PM
