Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-12-2009, 10:45 AM   #1
Electrician
Question
leveling a ceiling
I am currently tiling a bathroom floor, walls, and ceiling. there is a border at the top of the wall that would look bad if I had to cut it to accommodate the uneven ceiling. the difference is 3/4" in a 7' span. I can adjust the tile to end at the lowest part of the ceiling but that would leave a unsightly gap that will be noticeable when the ceiling tile met it. I was thinking about a skim coat of compound or plaster but I don't want to put the wrong thing and ruin the tile work. what is a the best thing to do in this situation
spark-451 is offline   Reply With Quote
Old 02-12-2009, 11:24 AM   #2
Remodeling Contractor
leveling a ceiling
To do it right remove the sheetrock and shim the ceiling to level and drywall it again. This will give you an opportunity to use mold resistant drywall.
Old 02-12-2009, 12:00 PM   #3
Drywall contractor
leveling a ceiling
That would definitely be the correct way to do it.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Leveling a sunken ceiling oxicottin Remodeling 9 05-18-2008 11:49 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Leveling an old ceiling jduhoski40 Building & Construction 4 01-24-2007 12:54 PM
