Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-24-2009, 08:53 AM   #1
countertops.
levelman is offline   Reply With Quote
Old 10-24-2009, 04:38 PM   #2
This is such a strange posting on so many levels. Especially from someone who says he's a contractor.
Any decent quality cabinets are made so any countertops can be installed on top of them. It's not the cabinets that are the issue, it's the floor the cabinets are set on.
Why would there be visable shims to stain or cover with molding after you set everyting "level" to within a 1/6". It's either level or it isn't.
Any competant cabinet installer should be able to set cabinets ready for any counter.
I really don't see the need to go to the extra expense for your services if there are shims that need to be stained to match or covered with molding.
That's what you're there to eliminate.
Ron
Old 10-24-2009, 05:04 PM   #3
General Contractor
Ron
I agree with the above statement for the most part. I would have to add the following: Installing the cabinets plumb and level is part of doing the job correctly. There should be no additional charge to the client for what is part of the job anyway.
ARI001 is offline   Reply With Quote
Old 10-24-2009, 07:10 PM   #4
Umm... my new kitchen cabinets were leveled (with shims) to the very unlevel concrete floor - tools used were a couple different length regular levels. Then the granite guys came in and installed plywood and the granite without having to shim addionally.
Maybe I am not understanding the OP...
More On This Topic
When mold grows in your home it can pose a hazard to the health of your family. Mold allergies can develop quickly and they will have many of the same symptoms as pollen allergies or pet allergies. It is critical that you test your home for signs of mold... Read More »
Ok, so, now all we have left to do, is get our bottom board in. And, what we'll do is, we'll just take this whole door off, see if that will give us enough room, for this to slide in. (Cough) Excuse me. Now, put our hinges back on. And, there we go. OK... Read More »
So, let's see if we can find some material that would make that shim. It looks as though, on this particular instrument that this unit here, is exactly for that purpose. But it is level so we can put a shim under here and we only need, maybe, a one... Read More »
Hi! I’m William Myers from Austin Subaru for Expert Village. Now that you have your wiper blade off we’re going to install an insert in this wiper blade and wiper arms this whole piece right here is a little more expensive than an insert but... Read More »
Beautify your garden with handmade stepping stones! Learn how to fit the mold for stained glass stepping stones in this free craft video. Read More »
Basement Renovation Question KUIPORNG Remodeling 235 08-26-2008 10:19 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General Discussion 15 07-21-2008 01:32 AM
Fiberglass Shower Base Install Q's yohan Plumbing 7 06-05-2007 03:41 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 05:21 PM
Base cabinets on floor TonyD Carpentry 15 10-24-2006 12:53 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
