Level Line For Baseboard Installation - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-12-2011, 07:39 AM   #16
wow, I didn't realize this would generate a debate...
I'm going to install the base today after giving it a first coat of paint.
It will be best this way as I can cut my pieces inside the room rather that outside in the 2 ft of snow.
This all brings up the question of scarf joints if I install the base using spacers.
Where the scarf joint ends up at a high point in the floor, I guess I have to miter the scarf slightly to compesate for the angle as the base goes from high to low spots?
williamwiens is offline   Reply With Quote
Old 02-12-2011, 08:21 AM   #17
Originally Posted by fungku View Post
He's a DiY'er doing one basement reno.
I don't think he's worried about production work here... just sayin'
Just giving him a different option, the finger method. Cause not everyone has a table saw to make 3/8" blocks.
sausagefingers is offline   Reply With Quote
Old 02-12-2011, 08:28 AM   #18
Rewards Points: 1,668
"This all brings up the question of scarf joints if I install the base using spacers.
Where the scarf joint ends up at a high point in the floor, I guess I have to miter the scarf slightly to compesate for the angle as the base goes from high to low spots?"
Place both lengths on the blocks so you don't have a weirdly pitched joint then nail it off. Cutting compound angles will drive you nuts.
bob22 is offline   Reply With Quote
Old 02-12-2011, 01:40 PM   #19
Rewards Points: 5,336
Using spacers just telegraphs the floor issues to the wall.
Snap a level line on the wall and install to that.
Ron
Old 02-12-2011, 03:49 PM   #20
Framing Contractor
There's no debate. You always install base before the carpet. Raise it up a little It's that simple. Good Luck.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
fungku (02-12-2011)
Old 02-12-2011, 11:08 PM   #21
Registered User
Rewards Points: 526
I always follow the floor with 1/2" spacers. You fill the nail holes before painting the final face coat before carpet. IF you level line, the carpet will show a gap to the base when the floor dips. The base usually will not bow down enough to look bad, more of a gentle curve, don't force it...
Gary
questions about best way to level sub-floor for hardwood installation cbendock Flooring 4 12-08-2010 05:48 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 04:13 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
establish level line on pilings johnwells Building & Construction 2 08-12-2008 08:13 PM
