Length For? Quick Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 10:07 AM   #1
Length for? Quick question
16" center floor joists
Anyone know right off hand what would be the ? for Herringbone Strut?
Length = ?
Angle Deg = ?
How often should I have a Herringbone Strut over a 16' Span?
DukeLewis87 is offline   Reply With Quote
Old 07-06-2013, 10:08 AM   #2
Picture:
Old 07-06-2013, 10:29 AM   #3
Or someone mind telling me how to figure it out with a 6" square maybe?
Old 07-06-2013, 10:45 AM   #4
kwikfishron's Avatar
Rewards Points: 772
Just lay a couple of short cutoffs of the joist stock on a table at 16"oc then lay a piece of the strut stock on that and scribe the angle. You could do the same thing just by drawing it out too.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
hand drive (07-08-2013)
Old 07-06-2013, 12:35 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
On the distance....I think it's every 8'. In your case....with a 16' span....blocking in the middle.....I think....
ddawg16 is online now   Reply With Quote
Old 07-06-2013, 01:27 PM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,316
Just curious....
Anyone know if there is any structural advantage to using Xbracing verse solid blocking..... (I've seen solid called out in Cali.... don't think I've ever seen X called out (just blocking) (except on TJ's maybe)
MTN REMODEL LLC is offline   Reply With Quote
Old 07-14-2013, 09:44 PM   #7
Haverhill Trade 1965
Around New England it is called cross bridging. It does not have to be exact length to work, it only looks neater. Some joist spaces may vary a little so we used to make it flush at the top with all landing about 1/4" above the bottom of the joists. Cross bridging works under compression from top of one joist to the bottom of the two adjacent joists. Nailing the ends tight is more important than being the exact length. Solid bridging or blocking prevent the rectangle space between joists from becoming a parallelogram thus spreading the load over several adjacent joists. They should all be cut individually so they are tight but not tight enough to push the joists apart. They should be center of any span over 10' and divided in thirds over 16'. But check your codes because some spans under 16' may call for two rows.
Duckweather is offline   Reply With Quote
The Following User Says Thank You to Duckweather For This Useful Post:
MTN REMODEL LLC (07-14-2013)
Old 07-16-2013, 03:02 PM   #8
In case anyone else reads this, cross bridging should be installed in pairs on alternate sides of a line with tops and bottoms directly opposite each other. Solid bridging is easier to nail if alternately staggered to either side of a line
MTN REMODEL LLC (07-16-2013)
Old 07-16-2013, 08:53 PM   #9
JOATMON
ddawg16's Avatar
I did all my blocking in a straight line.....it was easy to nail...just line up the nailer at a slight angle from the other side and hit it. The staggered blocking bugs me. I like things lined up.
Old 07-16-2013, 09:26 PM   #10
"I like things lined up".... me too...like beers on the bar.
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
ddawg16 (07-16-2013)
Old 07-17-2013, 09:38 AM   #11
But if some are new enough to ask some of these questions they probably don't have the experience or tools capable of doing what a pro easily can.
Old 07-17-2013, 09:56 AM   #12
JOATMON
ddawg16's Avatar
Ever hear the expression "You learn by your mistakes"?
Why do you think I'm so bloody smart now?
Have to start some where.....I'm an engineer...(among other things). I'm doing this for fun....I'm not fast...and I doubt I could make a living at it....but I'm having fun...and getting a lot of free advice here....
btw mods....we need the :beer: icon.....
Old 07-18-2013, 07:46 AM   #13
I'm not fast but I'm not slow. Sometimes I am half fast though.
Old 07-26-2013, 10:27 PM   #14
Registered User
Rewards Points: 526
Originally Posted by MTN REMODEL LLC View Post
Just curious....
http://www.ewpa.com/Archive/2004/jun/Paper_278.pdf
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
MTN REMODEL LLC (08-01-2013)
Outdoor Wiring Question OKDrew63 Electrical 30 08-14-2012 11:25 PM
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 07:44 PM
total effective length question drewhart HVAC 2 01-27-2009 08:46 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
