Length Of Angled 2x4 - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-12-2014, 04:48 PM   #1
length of angled 2x4
Evening folks. This might be a dumb question so I apologize in advance. Anyhow im going to build a display stand for my wife and im trying to figure out how long a 2x4 cut at a 45 degree cute needs to be on both ends so that its sqauare to the ground. I want the overall height will be 34.5 inches. This is what i was talking about in case what i typed didnt make sense. Im assuming that those are 45. I dont have any plans so im just trying to copy the pic. Thanks for the help.
[IMG][/IMG]
shaydu is offline   Reply With Quote
Old 03-12-2014, 05:24 PM   #2
Ok i just remembered geometry 101. The Pythagorean theorem. If I did it right it should've right around 49 7/8in.
Old 03-12-2014, 05:36 PM   #3
kwikfishron's Avatar
Rewards Points: 814
48-13/16" long to short.
kwikfishron is offline   Reply With Quote
Old 03-12-2014, 09:02 PM   #4
Thanks. I guess my math was wrong. How did you figure that out?
Old 03-12-2014, 09:35 PM   #5
Rewards Points: 814
Simple and no math (this time).
As I sit here in my seat I saw a 4x8 sheet. I measured 34.5 up one way and then same square off the other. Pull a tape between the dots and there ya go.
The Following User Says Thank You to kwikfishron For This Useful Post:
loneframer (03-13-2014)
Old 03-13-2014, 06:55 AM   #6
KemoSabe
loneframer's Avatar
1.414" is the diagonal of 1" on a 45 degree angle, within a fraction of 1/1000 of an inch. 34.5" x 1.414=48.783", or just a hair over 48 7/8".
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 03-13-2014, 07:31 AM   #7
joed's Avatar
Rewards Points: 13,332
But you need to start with a 2x4 that 3.5 inches longer than that to have enough wood to get the 45 cut at the top.
Old 03-13-2014, 07:47 AM   #8
Rewards Points: 814
Wouldn't that be a hair under 7/8"?
Old 03-13-2014, 07:51 AM   #9
Rewards Points: 1,684
Not if you memorized your decimal equivalents as a kid.
Old 03-13-2014, 09:31 AM   #10
Old 03-13-2014, 10:01 AM   #11
concretemasonry's Avatar
Rewards Points: 2,626
For the diagonal length, you have to reduce the 34.5" overall height by the thickness of the top shelf. After that, it is just geometry if you want to go with the 45 degree assumption.
concretemasonry is offline   Reply With Quote
Old 03-13-2014, 10:46 AM   #12
The overall high will be 36 inches. I already subtracted the width of the top shelf. Probably should've mentioned earlier but the overall depth is going to be 36 inches as well
Thanks for the help
Old 03-13-2014, 10:50 AM   #13
Do you have a table that use that gives the diagonals! If so could you provide a length?
Old 03-13-2014, 04:14 PM   #14
Rewards Points: 814
The conversions are still burned in my brain. Long before CM calculators they were it. You couldn't build much without them. I still use them to this day.
Old 03-13-2014, 08:16 PM   #15
Rewards Points: 2,638
I prefer to sketch it out. If this is what you are planning, then the length is 48.79"
SPS-1 is offline   Reply With Quote
1/2" NPT brass nipple with 3 1/4" length needed. noone Plumbing 10 08-09-2013 05:49 AM
interior wall frame has an angled piece at bottom of one stud. Why! waitingtohear Building & Construction 14 05-03-2012 08:50 PM
Glass shower door for custom angled shower toocheaptohire Kitchen & Bath Remodeling 6 12-31-2011 08:43 PM
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 09:03 AM
Hardwood Length...preference? JDeFuria Flooring 3 03-10-2009 05:38 PM
