11-24-2011, 10:53 AM
#1
laying out a wall with degree given
need to layout a wall with a degree other than 45,90,or 135 degree
11-24-2011, 11:06 AM
#2
Experienced
Hello and welcome cjtwofour, to the best darn DIY'r site on the web.
=ATAN(C4/C3)*180/PI()
Plug this into an excell spread sheet C4 and C3 are the lengths of the walls.
This would be the diagnal measurement =SQRT(C3^2+C4^2)
Mark
When its all said and done there is usually more said than done To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
11-24-2011, 12:17 PM
#3
Old School
The Dummy's way:
If you drew a circle 10 feet in diameter (5' out from the start of your wall) .... at that 5' point, each degree would measure one and a sixteenth of an inch, (1-1/16"), straight across to the next degree. (1-1/16" is not perfect to the thousandth, by the way, but it is plenty close enough for laying out a wall.)
So a wall laid out at 20 degrees off the original benchmark line would be done by measuring in a straight line (point to point on the radius arc of the circle) 1-1/16" , twenty times........ DO NOT simply try to do this with ONE straight measurement of 20 times 1.0625. It will not work right that way. Do it degree, by degree, by degree along the line of the circle, using straight, point to point measurements. (Don't try to measure in a curve along the circle by bending the tape either.)
Yes, this will take a few minutes, but it is a simple, easy way to get what you need right there in the field.
Willie T
11-24-2011, 12:19 PM
#4
Experienced
Originally Posted by Willie T
The Dummy's way:
So a wall laid out at 20 degrees off the original benchmark line would be done by measuring in a straight line (point to point on the radius arc of the circle) 1-1/16 , twenty times........ DO NOT simply try to do this with ONE straight measurement of 20 times 1.0625. It will not work right that way. Do it degree, by degree, by degree along the line of the circle, using straight, point to point measurements. (Don't try to measure in a curve along the circle by bending the tape.)
Unless of course you are carrying a calculator.......
11-24-2011, 12:24 PM
#5
Old School
Yeah, a calculator is a tool I see in just about every carpenter's apron.
Willie T
11-25-2011, 02:47 PM
#6
What would the formula be to use with a calculater? Say a wall with a 88.6 degree angle.
11-25-2011, 04:03 PM
#7
What walls are you building that needs a special formula that's 1.4 degrees off of a 90 degree wall?
Ron
B. Franklin 1759
11-25-2011, 05:19 PM
#8
If you are framing in a basement wall that is out of square, or similar remodeling project, forget the protractor; snap a line on the floor or ceiling, connecting the points that you want to meet, use a plumb bob or level to lay out the other one, and call it done.
11-25-2011, 08:25 PM
#9
Old School
I suspect that would turn out looking more like just a mistake in the layout than anything.
I also have to ask what the heck you're trying to build.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
11-26-2011, 10:40 AM
#10
Framing Contractor
Can you explain exactly what you are trying to do? What kind of calculator are you using? That will help with the answers.
Joe Carola
11-26-2011, 10:53 AM
#11
Experienced
Removed that was for 90* angle.
11-26-2011, 11:19 AM
#12
I carry 2 calculators, although not in my pouches. It's either that are a lot of figuring written on the wall
11-26-2011, 03:49 PM
#13
I have a 3foot wall with another wall coming off of it at a 88 degree angle. wasn't sure if a construction master calculator would help with this task. Also have some 60 and 40 degreee walls in this kitchen and bar area.
11-26-2011, 05:10 PM
#14
Framing Contractor
The CM is easy to use for this. Which one do you have? Do you have the one with Trig?
Joe Carola
11-26-2011, 05:32 PM
#15
I don"t have one yet. Just wondered if there was an application on it that would give a formula to get a measurement off the 90 or off a 45.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
