Laying Out A Wall At 75 Degrees - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-01-2011, 06:05 PM   #1
laying out a wall at 75 degrees
Can anyone tell me if there is a formula for laying out a wall at 75 degrees? If I start with a 90 degree wall what would be the measurement off of the 90 degree line to get a 75 degree angle? In other words if I travel up 12 inches from a set point how many inches horizontally would I need to get the angle? I'm thinking its around 3" or so but wanted to check. Thanks
glavstav is offline   Reply With Quote
Old 03-01-2011, 06:18 PM   #2
Experienced
Jackofall1's Avatar
Draw a square line from the base at 12" a 75* line would be 3-3/16"
By the way welcome to the best DIY'r site on the web
Mark
Old 03-01-2011, 08:10 PM   #3
Thanks for the help
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
