Laundry Room Floor Plan - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-02-2011, 11:06 AM   #1
laundry room floor plan
hi,
my laundryroom is in the far end of my unfinished basement. i would like to take a chance and get my husband to build a laundryroom. we have 3 walls around the aread where the laundry machine is, we need to build the 4th wall with a door and off course the whole process of drywall and other things that involves. is there a recommendation on how to start on this project and where i could find few drafts and layouts? my husband is not really good in putting his plans on the paper first so i got to come up with something for him. anyone with a great idea?
p.s. just above the laundry machine there is a power unit/box ( not sure with the name) that needs to be box around to hide it from the eye sight.
thanks.
mf
mashal is offline   Reply With Quote
Old 06-02-2011, 05:29 PM   #2
Rewards Points: 5,336
Sound like you just need a wall with a door. You don't need alot of planning with this. The door needs to be at least 30" wide to get the units in and out.
What sort of tools does he have and experience building a partition wall and finishing drywall?
Ron
Old 06-03-2011, 12:51 PM   #3
Registered User
Rewards Points: 5,462
You will probably need a permit to be safe and for re-sale.
"p.s. just above the laundry machine there is a power unit/box ( not sure with the name) that needs to be box around to hide it from the eye sight. "--------
http://publicecodes.citation.com/ico..._34_sec005.htm
Gary
Gary in WA is online now   Reply With Quote
Old 06-14-2011, 07:41 AM   #4
hi, he is good and still learning. he has few tools or he can borrow or rent tools if its required. the laundry units are in the basement where on the first floor a bay widow is located so its not totally 3 full wall but 5 walls all together. (3 large and 2 small as the shape of the bay window). this shape makes things hard for him to build the laundry room. any suggestions and pictures or links? i will attach few pics soon.
tnx.
Ron
Old 06-14-2011, 09:31 AM   #5
Rewards Points: 459
Have you tried Google Sketchup? Its a free program with lots of online tutorials (including some great youtube videos). It's intuitive, fairly easy to use and allows you to make a true 3d model and adjust it as necessary.
Nick DIY is offline   Reply With Quote
The Following User Says Thank You to Nick DIY For This Useful Post:
mashal (06-29-2011)
Old 06-16-2011, 11:49 AM   #6
Too Short? Cut it Again!
I would hit the home improvement section of the library and grab a couple books on laundry rooms as a starter. Many will have floorplans.
For my own plans not requiring detailed CAD drawings, I love Sweet Home 3D. I have tried many others but this program beats them all hands down. It is an open source project with great add-on symbols libraries. It is free. Like Google Sketchup it does reasonable 3D representations too. It builds take off lists and even adds interior or exterior dimension lines if you want them.
http://www.sweethome3d.com
I too would recommend a permit now to keep things neat and clean for resale and especially if you are going to run any electrical or plumbing in the new wall.
The Following User Says Thank You to user1007 For This Useful Post:
mashal (06-29-2011)
Old 06-17-2011, 08:30 AM   #7
It's a laundry room wall and door. You should be able to figure it out without a software program.
Mark the floor with a piece of chalk and figure out how much material you need.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
mashal (06-29-2011)
Old 06-19-2011, 09:32 AM   #8
laundry room wiring brit in canada Electrical 3 01-07-2011 09:45 PM
Well Room (Cold Room) Issue--Advice Needed TomPgh Building & Construction 11 01-03-2011 06:31 PM
Renovating the Laundry Room in 7 days newbsauce Project Showcase 4 10-12-2009 11:43 AM
occasional sewer gas smell in laundry room nebben Plumbing 3 03-25-2007 10:35 AM
Supply and Return from Laundry Room bjstewa HVAC 7 03-02-2007 11:39 PM
