Latice Spaces Calculation - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-13-2012, 10:13 PM   #1
Latice spaces calculation
Hi all
My math aint the best (I am being polite here) so i need some help figuring out something.
I am in process of building a horizontal lattice structure to fill the niche in the bathroom.
Its height is 100" and lattice pieces i have are 2" wide each. Wife wants ~1" slits between them. So..... How do i do this so all of the slits are same size and yet i do not end up with like 1/4" strip at the end because full 2" does not fit?
Thanks a ton!
Eugene
25PSi is offline   Reply With Quote
Old 02-13-2012, 10:17 PM   #2
Rewards Points: 14,312
A picture would be nice.
Why not just use vinyl lattice with 1" spacing? No priming and painting.
Old 02-13-2012, 10:27 PM   #3
Fair point. Here is a photochop mock up.
I am using those numbers for simplicity. Want to figure out how to do this right.
Old 02-13-2012, 10:36 PM   #4
Totaly differant then what I was picturing. I'ts your house and of course you can do as you please, but that's going to be nothing but be a dust trap.
Warm moist dust laden air is going to just lay on top of that mess.
Use striped vinyl wall paper or just paint the lines.
Old 02-13-2012, 10:42 PM   #5
http://www.ehow.com/how_6704269_calc...r-spacing.html
This shows how to space ballisters but the princable is the same.
Where it says in rule 5 to measure the lengh of the rail, just measure from back splash to top of wall instead.
Old 02-14-2012, 05:44 PM   #6
Rewards Points: 77
Using your example, 1 strip + 1 space= 3". You have 100" total. There will be an ending strip at the top that does not have a space after it so subtract that from the 100" to get 98". Divide 98" by 3"=32.6666 sets ( a strip + a space). Round that up or down to an even number, say 33 sets. Now re-divide 98" by 33 = 2.9696 or 2 31/32" per set. So you would make some 31/32" spacers to put between your 2" strips, get out your magnifying glass and calipers and start installing. You should end up within 1/64" + or - 1" by the time you get to the top...just kidding. The accuracy of your mark out lines and consistancy of your 2" strips will determine the outcome. Is that as clear as mud?
MNsawyergp is offline   Reply With Quote
Old 02-14-2012, 05:58 PM   #7
Yep clear as brown water
However there is a complication I need those latices to be in line with the top and bottom of the mirror to make it look good. So, this would make it a bit more challenging as it will present this as 3 different zones. Suggestions?
Old 02-14-2012, 07:26 PM   #8
retired union carpenter
Send a message via Yahoo to coupe
start in the middle and work both ways up and down?
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-15-2012, 02:53 PM   #9
mem
Rewards Points: 156
Take the mirror down and rehang at the required height!
mem is offline   Reply With Quote
proper calculation for circuit size withoutlicense Electrical 19 02-16-2012 09:15 AM
1CFM per square foot, or follow heat load calculation? JeepNick HVAC 10 02-08-2012 04:10 PM
Beware of Inappropriate Load Calculation Software - Source ACCA.org JJboy HVAC 5 09-06-2011 06:25 PM
Load Calculation Fee - HVAC Contractors Please DIYerIT HVAC 2 07-30-2011 04:39 PM
Load Calculation ? RM575 HVAC 9 07-04-2007 12:37 PM
