Larger Door Opening - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-20-2010, 02:13 PM   #1
larger door opening
I have purchased a larger door with a side window that is 54.25 " X 82" and the old opening is 35"X82"whats the eaisest cheapest way to redo the opening to fit the larger door ? also this is a maufactured home if it makes a difference. the measurments are for the frame not the door.
RM POWELL is offline   Reply With Quote
Old 09-21-2010, 05:56 AM   #2
Not sure about manufactured home construction, but in normal house construction, any opening needs a header to support the sturcture above the opening and the span. I assume it is the same in manufactured homes. You need to open the wall and make a new header.
Old 09-21-2010, 07:12 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Pretty major job you are looking at.
Remove interior wall surface (drywall?)
Remove exterior siding and sheathing
Relocate any wiring in proposed opening
Built temporary wall inside to support roof. (Assuming a single story building, this does not have to be overly heavy duty for a manufactured home)
Cut out as many studs as required.
Build new header to cover new opening plus 3 inches on each end (6 inches total for 4 jack studs).
Install king stud and 2 jack studs on either side of opening.
Replace sheathing and interior wall surface.
Install new door
Replace siding
Coastal South Carolina
Old 09-21-2010, 01:41 PM   #4
Registered User
Rewards Points: 5,520
And look below to see if you have bearing (1-1/2" rim joist- compare to old) under the new point loads. Check for wiring or plumbing in the way while down-under. Turn off power to area, switches and outlets.
Gary
Old 09-21-2010, 04:51 PM   #5
Framing Contractor
Do you mean a Modular Home?
Joe Carola
Joe Carola is offline   Reply With Quote
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Larger ceramic tile on drywall? HABSFAN2006 Drywall & Plaster 8 05-29-2009 03:24 PM
How to Cover 1" and larger knockouts? theatretch85 Electrical 11 12-24-2008 02:34 PM
Larger hole in foundation jamiedolan Building & Construction 5 10-02-2008 11:04 AM
Adding Larger electrical Box Bigbobdallas Electrical 1 11-06-2007 01:02 PM
