Lan Beam Sizing - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-03-2008, 12:41 PM   #1
Lan beam sizing
I am removing a post in my garage and will be running a lam beam to support the load (30 p/sqft) 14' distance. Beam to be 51/2" but how deep? 10" ?, 12"?
Robert
orcasrob is offline   Reply With Quote
Old 08-03-2008, 05:05 PM   #2
Registered User
Termite's Avatar
I would suggest going to a lumberyard...NOT A BOX STORE...A SPECIALTY LUMBER YARD that sells engineered wood beams (LVL, PSL, GluLam, Timberstrand, etc). Most good yards will have the capability to run your home's specific loads and dimensional requirements and can tell you what you need and provide engineered calc's from their proprietary manufacturer's program to back it up.
Old 08-03-2008, 06:53 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
......Exactly what KCT said.....
- Build Well -
Old 08-03-2008, 07:06 PM   #4
Registered User
Termite's Avatar
By the way, if you're buying the beam from them, the engineering is free.
Old 08-05-2008, 08:21 PM   #5
Lam Beam question
Okay, thats great. I will give it a shot. It isn't a big span, only 15' so it isn't rocket science.
RSP
Old 08-05-2008, 09:05 PM   #6
Registered User
Termite's Avatar
Just don't shoot from the hip on this! As simple as it seems, an undersized wood beam's deflection over a 14' span can definately be felt in the floor above, which might start to feel a lot like a trampoline.
Tags
lam bean size?
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
Beam Sizing Riddler Carpentry 14 08-05-2006 12:46 AM
