Laminte On Countertop With Wood Bullnose - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-12-2009, 12:42 PM   #1
Laminte on countertop with wood bullnose
Anyone know how to cut this?
Cmon you pro's, advanced DIYers you know how to do this and have never failed me yet.
Tell me the scoop.
just want to put laminate on with glue then trime the edge. the edge is finished oak bullnose.
Thanks guys/gals.
luweee is offline   Reply With Quote
Old 08-12-2009, 12:48 PM   #2
Run a laminate trimmer along the edge and then glue/screw the edging? Or, put the laminate over the edging and run a bevel router bit over the edge? What kind of look are you going for?
jerryh3 is offline   Reply With Quote
Old 08-12-2009, 03:33 PM   #3
Registered User
Termite's Avatar
The laminate must be installed with contact cement. Follow the application directions on that and get a bunch of 1/2" wood dowel rods to make the process of laying it down easier. Then use a j-roller to roll it down and make the adhesive layers really grab to each other.
As stated, a laminate trimmer is a must. Use it once the laminate is glued down. That's basically a small router. A regular router will work as well, it just won't fit in small spaces and close to walls. A flush trim bit is used prior to application of the bullnose. If the bullnose is already there it'll be tough to make it look good because the bit's bearing has to ride the edge of something and I don't see that working with some bullnose profiles and cutter/bearing configurations.
Old 08-12-2009, 10:54 PM   #4
Old School
Willie T's Avatar
Or........... go the "no-cost" route, and use something you probably already have on hand... a long, round extension cord. Simply loop the cord back and forth, and back and forth, about every 6", (from side to side), so that the cord fully supports the laminate above the countertop like a forty foot long, windy snake. Then, after aligning the laminate just right, push down on one end, firmly affixing it to the end of the countertop. Then begin pulling on the cord to progressively slip it out from under the laminate, letting the laminate contact the countertop about 6 more inches at a time as the cord is finally pulled out. (You do this starting at one end, and progressively working to the other.) When all the cord is pulled out, the laminate will have been steadily and perfectly lowered into contact with the countertop.
Willie T
Old 08-13-2009, 08:52 AM   #5
Registered User
Termite's Avatar
That's a pretty good idea!
Old 08-14-2009, 08:08 AM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
Is the bullnose already attached? If it is, does it have a ridge for the laminate to sit behind? If not, then I would build the top and apply the laminate. Flush trim it on the edge with a router or laminate trimmer, then attach the bull nose with biscuits. Either get a biscuit joiner or a router bit to cut the slots.
Old 08-14-2009, 09:17 AM   #7
Old School
Willie T's Avatar
By the way, when working a long piece of laminate, make sure to adhere the center portion of the long strip first, rubbing outward toward the edges. Never let both edges make contact before the center. This could cause a bow or buckle in the center that you can't work out because the two sides are already firmly stuck down.
Remember laying laminate down is a slow, progressive process. Make sure where you are is smoothed out right before you move on down the line.
Trick: If you make an alignment mistake, all is not lost. Contact cement readily and quickly loosens by dribbling some Lacquer Thinner into the joint (curve) and peeling the laminate back. Small paint brushes and putty knives often make getting the Lacquer Thinner into the joint a bit easier. If you can stand the work vertically, all you need to do is dribble the LT back and forth along the curve... gravity does the rest as you peel.
Willie T
Old 08-14-2009, 09:39 AM   #8
Old School
Willie T's Avatar
Some people do not realize this, but laminate "grows" for a day or so. What this means is that as the glue chemically cures and saturates the laminate backing, the material relaxes. This causes a problem how?
Well if you insist on trimming immediately after rolling out the laminate (which you should [MUST] do... "roll", I mean) the laminate will seem to have "grown" a little the next day, requiring more finish edge filing. Just let it sit till tomorrow before you trim it. You will find that those aggravating loose corners that you sometimes encounter will stay attached better if you wait a day on the trimming, too.
We're mainly DIY'er, so we can afford this small delay.
CAUTION: Everyone already knows to use Vaseline or some kind of lubricating oil on the previously laminated edges where the trimmer bit will ride for cutting the adjoining piece, right? You can burn that nice laminate finish with a high speed bit nose. The Vaseline keeps that from happening. Forget to use it, and I guarantee you WILL burn a spot sometime.
ALSO.......... Keep the dried glue cleaned off your bits by wiping them every few passes with a LT soaked rag. It makes for a cleaner cut. Be smart.... unplug the trimmer when you do this !!!!
Willie T
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
