Laminate Transition At Entry Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-15-2010, 08:15 AM   #1
Rewards Points: 264
laminate transition at entry door
Yesterday we installed laminate flooring in a neighbor's house and only had one hang up: the old floor was level with the entry door to the garage and there is no threshold . We didn't take up the old flooring so by adding laminate we have raised the floor 1/2". I see our options as 1) run laminate under the door to the edge of the step and cut the door down (its wood, not steel) or 2) use a bull-nose transition piece at the door. HO doesn't want to do the bull-nose because he thinks a 1/2" step up inside the door is going to look bad. I think cutting the door down is more odd. Thoughts? How is this typically done?
Thanks !
moneymgmt is offline   Reply With Quote
Old 03-15-2010, 08:31 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
The best solution is to raise the door. This involves removing the door and frame. You may have to increase the height of the header. This will also alow you to install a threshold.
Coastal South Carolina
Old 03-15-2010, 08:36 AM   #3
Rewards Points: 264
Originally Posted by rjniles View Post
The best solution is to raise the door. This will also allow you to install a threshold.
LOL.... in my house, maybe. In his house, lets just say I had to bring all the tools to do what we did. The BEST solution would have been to remove the 30 years and 2" of flooring and subfloors, but he didn't want anything to do with that......
Old 03-15-2010, 08:55 AM   #4
I would tell him he needs threshold since garage and house shouldnt be on same level anyway. that way there is some seperation
The older I get the better I was
Old 03-16-2010, 09:59 AM   #5
Rewards Points: 264
moving to flooring room... oops!
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Installing steel entry door NoExperience Carpentry 2 10-23-2008 11:23 AM
Prehung entry door gap problem 1fstws6 Building & Construction 3 03-21-2008 07:45 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
