Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-04-2010, 09:37 PM   #1
Laminate thickness in a basement
Evening folks;
I am putting laminate down in my basement. There is a very nice laminate that is 8mm, for an additional cost the same laminate is available in 10mm. It s a big room and I would prefer to use the more cost effective 8mm. Is there any pros or cons I should be aware of? Should I spend the extra money for the 10mm, does it matter?
Thanks all.
BigYin1979 is offline   Reply With Quote
Old 12-05-2010, 07:57 AM   #2
That is about 1/16", not a lot for sure, but what is the cost difference???
DO put down the moisture barrier underlayment. Most manufacturers make their own underlayment, so follow directions or warranties could be hard to get.
Old 12-05-2010, 11:43 AM   #3
Originally Posted by BigYin1979 View Post
Evening folks;
Thanks all.
Is any of the thickness difference in the surface layer? If it is and your basement is a high traffic area, then you might want to consider it.
mrgins is offline   Reply With Quote
Old 12-06-2010, 02:02 AM   #4
Also go with the acoustical underlayment if possible. It is a higher quality and will help stop the clicking noise you hear on some floating floors
Docwhitley is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 10:43 AM
Laminate on basement floor, but there is a drain there nag Flooring 6 06-10-2010 09:59 PM
5 year old house, flooring requirements for basement? SDG Flooring 5 09-23-2008 10:53 AM
Laminate in Basement Question atilla137 Flooring 16 11-10-2007 08:44 PM
