-   -   Laminate thickness in a basement (http://www.diychatroom.com/f14/laminate-thickness-basement-88620/)
BigYin1979 12-04-2010 08:37 PM
Evening folks;
I am putting laminate down in my basement. There is a very nice laminate that is 8mm, for an additional cost the same laminate is available in 10mm. It s a big room and I would prefer to use the more cost effective 8mm. Is there any pros or cons I should be aware of? Should I spend the extra money for the 10mm, does it matter?
Thanks all.
Just Bill 12-05-2010 06:57 AM
That is about 1/16", not a lot for sure, but what is the cost difference???
DO put down the moisture barrier underlayment. Most manufacturers make their own underlayment, so follow directions or warranties could be hard to get.
mrgins 12-05-2010 10:43 AM
Originally Posted by BigYin1979 (Post 545571)
Evening folks;
Thanks all.
Is any of the thickness difference in the surface layer? If it is and your basement is a high traffic area, then you might want to consider it.
Docwhitley 12-06-2010 01:02 AM
Underlayment
Also go with the acoustical underlayment if possible. It is a higher quality and will help stop the clicking noise you hear on some floating floors
