Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-10-2012, 11:15 AM   #1
Still Learning
laminate kitchen countertops
Does anyone have any good ideas on how to fix a messed up cut of a laminate countertop with a built in backsplash? I used a jigsaw and the blade didn't cut straight and my angle is a little off...
thehvacguy is offline   Reply With Quote
Old 10-10-2012, 11:25 AM   #2
Maryland
Where is the cut located in relation to appliances? Any chance you can snap a photo showing the area?
Pittsville is offline   Reply With Quote
Old 10-10-2012, 12:05 PM   #3
DIY Enthusiast
sublime2's Avatar
Belt sander.
In the future,use a circular saw with some painters tape.
Makes quick work of the cut and its clean.
sublime2 is online now   Reply With Quote
Old 10-10-2012, 12:35 PM   #4
sdsester's Avatar
Any chance you can clamp a straigtedge and try again? Be sure and apply masking tape to the top so you don't tear up the laminate.
No easy way to fix the backsplash if that is where your cut went bad since most sanders will not reach it. My Fein oscillating saw did a nice job in these situations. You can pick up an equivalent for $40 or so I think although the $300 I paid for mine was one of the best investments I made.
sdsester is offline   Reply With Quote
Old 10-10-2012, 12:42 PM   #5
DIY Enthusiast
sublime2's Avatar
Why wouldn't the sander reach it?
Am I missing something?
Old 10-10-2012, 01:59 PM   #6
sdsester's Avatar
Oops. My mistake. Just watch that belt sander edge along the wall trimming the backsplash.
Old 10-10-2012, 02:15 PM   #7
Still Learning
The messed up part was on the 45 degree angle. I used a chop saw for the backsplash so that's good, and I clamped a 2x4 guide and put masking tape when I used the jig saw, its just that the blade cut at an angle so I started filing it down and now its all weird...
Old 10-10-2012, 04:51 PM   #8
DIY Enthusiast
sublime2's Avatar
Put painters tape on top of counter near the edge,scribe a straight line along the edge on top of tape,
Hit it with the belt sander in the areas that are beyond the tape. Line till edge is straight.
Old 10-10-2012, 10:42 PM   #9
Still Learning
Man that's a good idea!!! I used this sort of hand file and it made it worse...
Granite Tile vs. Laminate Countertop (Kitchen) Cow 9 Kitchen & Bath Remodeling 7 01-25-2012 12:53 PM
New laminate floors in kitchen and living room Cmonica30 Flooring 5 01-06-2012 04:34 PM
Cutting laminate kitchen cabinet blueturtle Carpentry 3 11-11-2009 02:37 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Installing laminate in kitchen JDClark26 Flooring 1 05-07-2007 07:21 PM
