Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-17-2013, 11:48 AM   #1
laminate headache
how do i avoid glue build up on my trim bit when doing tops. This sometimes will take the finish off the piece i have already done
TOMF is offline   Reply With Quote
Old 01-19-2013, 11:27 AM   #2
Been Building since 1970
laminate headache
I Keep the bearings clean by storing my bit in a small jar of laquer thinner. Then use a few drops of oil on the bearings before use.
claymcc is offline   Reply With Quote
Old 01-19-2013, 11:33 AM   #3
laminate headache
The bearings are sealed and there's grease in them not oil, soaking them in laquer thiner is going thin out the grease.
Try rubbing the bit over some bar soap before using it.
Old 01-20-2013, 12:22 PM   #4
custom user
laminate headache
Is it happening after every cut? You could clean the blades beforehand but every cut would get old. Another possibility is to use a variable speed router and find the right speed that works. Sometimes slower is better.
JasperST is offline   Reply With Quote
Old 01-21-2013, 08:57 PM   #5
laminate headache
Waiting for the cement to dry (not sticky to finger) before you put the pieces together is best way, but I do check the bearing and wipe with acetone.
carpdad is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 10:43 AM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 08:38 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 01:04 AM
