Laminate Cuts - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-10-2010, 10:23 PM   #1
Rewards Points: 180
laminate cuts
Hi has anyone mitered the edges on theses laminate countertops before?Whats the tips to getting it just right and what tool is best?
-cant find any place local for cut and didnt buy them from store.
hidden 1 is offline   Reply With Quote
Old 08-10-2010, 11:34 PM   #2
Civil Engineer
Rewards Points: 4,956
If your laminate is formica or equivalent, the best way to cut is with a router with a formica cutting bit. You can get straight bits, trimming bits, and bevel bits, depending on the type of edge you are looking for.
Daniel Holzman is online now   Reply With Quote
Old 08-11-2010, 11:21 AM   #3
Rewards Points: 180
The cuts will be joined together for corners so im not looking for a style just a good clean fit..
Old 08-11-2010, 01:35 PM   #4
Handyman
Rewards Points: 512
I own a Rigid corded and a Ryobi cordless laminate trimmer. Both work well and the results are perfect. They are "palm sized" so very easy to handle. Just need to purchase the laminate bit. Rigid was about $110CDN and the Ryobi I got as an out-of-box sale for $30
canadaclub is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Can't decide: Laminate or Engineered? rogersmj Flooring 7 08-30-2009 08:10 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
Laminate Flooring Quarter Round Cuts no3jack Flooring 1 12-11-2006 08:30 PM
