Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-13-2011, 01:20 AM   #1
Laminate beam header for Pre hung door?
Looking to put a prehung door along a wall that will be built directly under a laminate beam in a basement.
Because the height of the floor to bottom of beam is only 80 1/2 inches,I will be unable to place a header in.
Thus,can I build two seperate wall sections,double studded for hinge and stop sides,and use laminte beam as a top plate for the prehung door?
Thanks in advance for your inputs.
spring3100 is online now   Reply With Quote
Old 11-13-2011, 09:01 AM   #2
Don't know why not. Just don't modify/cut the beam.
The Following User Says Thank You to Just Bill For This Useful Post:
spring3100 (11-13-2011)
Old 11-13-2011, 09:01 AM   #3
Why not frame the door properly and cut down the door? I just did this same exact thing.
stradt03 is online now   Reply With Quote
Old 11-13-2011, 10:55 AM   #4
journeyman carpenter
woodworkbykirk's Avatar
in your situation where height is a issue, framing either side of the opening will be fine minus the top plate. the only thing i would make sure to do is have the wall deadly plumb and straight so the door can be hung properly. from there you will probably have to cut an inch off the door itself to allow for the jamb header and 1/2" space under the door
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 11-13-2011, 06:48 PM   #5
Attachment 40871
Thanks for the feedback,but since the door will already have to be 78 inches,I wouldn't want to lose any more height if at all possible.
Old 11-13-2011, 06:55 PM   #6
Other than nipping off a 1/2 on the bottom for a capillary break against the concrete floor,a 78 inch prehung should fit in the 80 1/2 inch rough opening,or did I miss something?
Old 11-13-2011, 07:26 PM   #7
no. just stating that you have a rough opening of 80 1/2" right now. im guessing the prehung itself is 80" unless you just bought a slab and are going to make a custom jamb. with the jamb you will need a header for the frame, so to keep a proper reveal and to have something to nail trim to over the door.
Pre Hung door vs other captainj98 Carpentry 12 09-10-2011 09:40 PM
laminate flooring over basement door in floor... tonyg1 Flooring 0 08-18-2011 03:35 PM
9' garage door header ifixfxs Building & Construction 5 05-24-2010 02:15 PM
Laminate Floor into closet under door jam jromjam Flooring 1 07-10-2009 07:59 AM
Non load bearing wall door header? nocarpenter Building & Construction 10 06-11-2009 05:16 PM
