Ladder Rungs For A Kids Swing Set ?? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 01:24 PM   #1
ladder rungs for a kids swing set ??
Hello every one I hope I am posting in the right place some of the rungs on my kids swing set have rotted and now they are breaking were would I be able to find something like that or what would be a good replacement for these ??
ants1929 is offline   Reply With Quote
Old 06-21-2011, 01:48 PM   #2
Hello,
My name is Stephen Hill. If they are dowels you can buy them from Lowes and Home Depot in the trim isle. You need to find out how wide they are ( the diameter of the existing dowels ) so that you only have to make one trip. Break out the old dowels and replace.
http://www.handymanhill.com
Stephen Hill is offline   Reply With Quote
Old 06-21-2011, 02:12 PM   #3
Rewards Points: 780
Ants, I had the same problem with my playset. I replaced the dowels in the ladder several times over the past 10 years. Earlier this spring I noticed that the top one needed to be replaced again.
The problem with the dowels is that they don't make them out of pressure treated wood (at least not that I could find), so they rot rather easily. I used oak dowels the last time and it didn't seem to make a difference.
I ended up going to Menard's and getting a plastic-sided ladder that required me to put four 2x6" wooden steps in, which I had to buy and cut. I bought pressure treated lumber so that the steps stay safe for the kids for a long time.
I'll try to post a picture of it in a little while. If I had the skills, I could have built the sides of the ladder myself instead of paying for the plastic ones. You may be able to do that yourself.
gma2rjc is offline   Reply With Quote
Old 06-21-2011, 02:19 PM   #4
the Musigician
DangerMouse's Avatar
If you can post a picture of the ladder, it will help.
You too, Barb....
DM
Old 06-21-2011, 02:38 PM   #5
Great info hoping to see the pics when you can thanks
Old 06-21-2011, 07:40 PM   #6
Can aluminum pipe be used instead?
Old 06-21-2011, 08:50 PM   #7
Rewards Points: 150
Replace with 1-1/4 conduit.
josall is offline   Reply With Quote
Old 06-21-2011, 08:53 PM   #8
I agree
Old 06-22-2011, 12:49 AM   #9
Rewards Points: 780
Would conduit become slippery for their little feet when it's wet or when they have mud or snow caked on the bottom of their shoes or boots?
I found one of the pics I'm looking for of the old ladder, but this is a different computer and I haven't figured out how to re-size and load them into a thread yet. As soon as I do, I'll post the pics.
Barb
Old 06-22-2011, 06:26 AM   #10
Too Short? Cut it Again!
How did we get to 1.25 inch diameter whatever? Am I missing a post or was I racing and did not see a post with dimensions?
I was thinking pipe or conduit too. What about sand filled S80 PVC capped at the ends.
Lodgepole pine is incredibly strong and flexible. Trees 1.5" in diameter might have 150 years or more of ring growth almost perfectly straight up 100' feet in the air. You could turn them to your finished diameter, treat them, and be done. Treated wood splinters are nasty stuck in the foot though.
Pricey compared to other options but solid PVC, nylon or whatever rods/dowels would work?
Old 06-22-2011, 07:19 AM   #11
Rewards Points: 5,336
Use galvanized pipe.
Ron
B. Franklin 1759
Old 06-22-2011, 07:22 AM   #12
Does home depot or loses carry this type of galvanizes pipe. ?
Old 06-22-2011, 10:24 AM   #13
Yes they do. You just need to cut them to length.
Be aware is they're not tight in the holes you drill, you should drill a hole through the side rails and into one side of the pipe(insert a screw or nail) to keep the pipe from spinning in place.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
josall (06-22-2011)
Old 06-22-2011, 01:21 PM   #14
Plastic conduit with 'Ready Threaded Rod' (3/8") running through it would make a good rung.
Drill the stringers to fit the rod and use a washer and nut at each end to lock the rod in place.
Old 06-23-2011, 06:26 PM   #15
Stairguy
Millertyme's Avatar
Rewards Points: 508
1-1/2" closet pole. It usually comes in fir too which is perfect for outdoors.
Millertyme is offline   Reply With Quote
Redecoration without painting in kids' bedrooms feselleL Remodeling 2 05-07-2017 08:56 PM
Rubber mulch Vs. Kids Carpet mulch for backyard play system whataboutj Landscaping & Lawn Care 1 04-26-2010 10:22 AM
Need Veg Garden ideas for kids at a hospital Leah Frances Gardening Forum 2 04-21-2010 11:39 AM
Roof Hook w/ Folding Ladder. Good Idea / Bad Idea? jjohanson Roofing/Siding 2 10-17-2008 07:45 PM
