Ladder Lift - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-01-2011, 10:01 AM   #1
Ladder lift
I am painting my stairway walls this friday and was wondering if anyone on here had a clever way to prop up one side of the ladder (to compensate for stair height difference) while it's against the side walls of the stairway? I have a 17' "little giant" style ladder that folds from a A-style ladder to a extension ladder. Any help would be appreciated
JasonJr is offline   Reply With Quote
Old 03-01-2011, 10:07 AM   #2
Rewards Points: 1,580
I put my 8' step ladder on first floor landing at base of stairs and ran 2xs from stairs out to 2nd highest step of step ladder (sort of a gang plank effect from stairs) and used this to do walls. This was in an enclosed stairway and I don't weigh a gazillion pounds so your planking may need to be adjusted for strength issues, plank anchored at both ends, etc..Obviously this is not OSHA approved method but it worked.
bob22 is offline   Reply With Quote
Old 03-01-2011, 10:19 AM   #3
Thanks for your Idea,I was thinking about that too but I'm 5'9" and I really just to be able to cut in at the ceiling. Did you make the plank much higher that the step it was on?
Old 03-01-2011, 10:48 AM   #4
Turn your ladder the other way so its feet are on one tread. Put a shorter step ladder on the landing and run a plank across
mrgins is offline   Reply With Quote
Old 03-01-2011, 10:57 AM   #5
Yeah..... I'm stupid and should've figured that out myself from the first reply I received. Thank-you!
Old 03-01-2011, 11:02 AM   #6
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
You could build a platform out of 2x4's and ply that is flat on top, but 3-1/2" tall on one and and 28" tall (or whatever your risers are) on the other end and that bears on the treads in between. You would have to figure out how many treads/risers this platform would need to span to suit your ladder. You could move it up and down the stairs as need to reach all the various spots. Make sure it is stable, but don't over build it to the point that you can't move it.
WirelessG is offline   Reply With Quote
Old 03-01-2011, 03:47 PM   #7
Thanks you all who replied, I built this today and it works great.
Old 03-01-2011, 09:17 PM   #8
Doing it myself
Alan's Avatar
Rewards Points: 2,086
That is a really great idea. I'm going to build me one of those.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
JasonJr (03-03-2011)
Old 03-02-2011, 08:19 AM   #9
mem
Rewards Points: 156
With the Little Giant you can simply adjust one side of the A frame setup to be longer than the other to accommodate placing it on steps at different heights.
If you need to use it in the extension mode, they make a 'leg leveler' that clamps to one of the bottom legs and adjusts for use on uneven surfaces. I have this setup and it is extremely stable.
Ya got a nice ladder, use it to its fullest!
mem is offline   Reply With Quote
Old 03-02-2011, 08:32 AM   #10
Have to agree with mem on this on. I've also utilised a 2x4 and U-bolts to fashion a leg in a pinch, but I'm not suggesting anyone here try it!
Old 03-02-2011, 12:39 PM   #11
WirelessG's Avatar
Rewards Points: 698
That's exactly what I was thinking of.
Old 03-02-2011, 04:18 PM   #12
That leg lift looks hokey.
Old 03-02-2011, 04:41 PM   #13
mem
Rewards Points: 156
Well, while the photo may look hokey, it's anything but. It grips tight, adjusts simply and can easily be fastened to either leg as necessary. It can be adjusted flush with the original leg for level surfaces and stores right in place. It doesn't weigh sixty pounds and take up a corner of the basement when not in use. When using on stairs you don't need to move the ladder, move the platform and move the ladder again every time you move to a different area, just move the ladder.
And it's made by the same company that makes your ladder. Is your ladder hokey?
Old 03-03-2011, 12:14 PM   #14
Nope, just that leg lift looks hokey. Try not to get so upset about a simple statement I made. Thought this was a friendly place?
Old 03-04-2011, 06:56 AM   #15
mem
Rewards Points: 156
Oh no Jason, I'm not upset and didn't mean to come off that way. I'm just touting the virtues of streamlined simplicity and ease of use over a solution that is far more complicated, cumbersome and expensive.
Wiring up 220 for Auto Lift and Air Compressor Shinobi'sZ Electrical 11 02-19-2011 11:29 AM
Wiring a receptacle for a lift station hydrogeo99 Electrical 4 08-18-2010 01:04 AM
Plasma TV Lift Cabinet - Lift Won't Rise - Troubleshooting Hils61 Home Theater 4 05-21-2010 08:11 PM
Roof Hook w/ Folding Ladder. Good Idea / Bad Idea? jjohanson Roofing/Siding 2 10-17-2008 07:45 PM
