Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-19-2006, 12:04 AM   #1
harleyd1369
knotty pine paneling
Hi,
I am new here and new to home improvement. I want to install knotty pine paneling at a 45 degree angle over existing wall covering. What is the best way to attach it (adhesive or brads or a combination of both) and what would be the best way to bring the electrical outlets and switch plates flush with the new paneling. As I say I am relatively new to this. Any help would be appreciated.
harleyd1369 is offline   Reply With Quote
Old 11-19-2006, 04:11 AM   #2
747
registered
747's Avatar
Originally Posted by harleyd1369 View Post
Hi,
Nail into the tongue. I have a wall done in 45 degree knotty pine tongue and grove carsiding. I also have the ceiling in that room done in it also. I'm not sure what your talking about if it isn't tongue and grove knotty pine also refered to as carsiding. I found a pic on another forum of carsiding. This is exactly what the ceiling in my den is done in i also have a wall done in that at a 45 and another wall done in that running the same dirrection in that pic. Its a wall that seperates my den from my utility room. Finally there was a debate on this forum whether or not this is carsiding one guy said it wasn't that guy doesn't no what he is talking about because this is definately carsiding here in Illinois. Here is the pic from another forum. http://drywallinfo.com/images/boysroom.jpg
747 is offline   Reply With Quote
Old 11-19-2006, 07:08 AM   #3
General Contractor
joasis's Avatar
You can do both, but for sure, nail it. I have seen a guy recently use a contact cement to install it, but the problem is humidity changes cauase the pine to bow or flex, it would pop the paper off the drywall it is glued to, so nailing would be best.
Another thing is let the material set in your home, in a heated room, for a week or two before intall, so the material will acclimate amd you won't have tight joints when you put it up, and a week later, see lines opening up.
joasis is offline   Reply With Quote
Old 11-19-2006, 12:01 PM   #4
You can get sleeves for your electrical boxes that will adust to the added wall thickness and should be used to keep the plugs away from the new wood. I would also recommend that you wrap the plug with electrical tape to cover the wire and screws.
Definately nail you siding to existing studs. If you are using tongue and groove you can 'blind nail' the tougue and the following piece will hide the nail
good luck
mcwilson is offline   Reply With Quote
Can't find studs behind knotty pine paneling David S General Discussion 15 09-05-2010 06:56 PM
knotty pine paneling Unregistered Remodeling 2 03-22-2010 12:41 PM
Cleaning knotty pine t/g boards barks Painting 3 03-22-2005 12:13 AM
Cleaning knotty pine boards barks Remodeling 4 03-17-2005 09:55 PM
