Knotty Pine Ceiling - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 03:01 PM   #1
Knotty pine ceiling
I have a popcorn texture ceiling, do I have to scrape this off before installing knotty pine boards?
jpierre is offline   Reply With Quote
Old 11-04-2012, 03:03 PM   #2
Rewards Points: 12,794
Simple ansewer is yes.
Old 11-04-2012, 03:18 PM   #3
funfool's Avatar
Rewards Points: 534
Best answer is yes, A nice smooth surface to start with.
Depending how lumpy the surface is, I would use a scraper and get as much off as possible.
If that brings it to a acceptable level, may be all you need.
Will still be some lumps and bumps, since is all tongue and groove and tied in and float over what you have, should not be a big issue.
On the other hand, after dry scraping the ceiling, you start running a few courses and gives problems installing.
Then I would remove those and wet the ceiling down and do a complete removal of the popcorn.
Seems a good scraping with it dry would be enough, but would only know by looking at it after you scraped it.
funfool is offline   Reply With Quote
Old 11-04-2012, 04:23 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 996
where your going over it simply knocking down the high points should be fine..
if you wanted a smooth finish drywall finish some would say competely scrape it,, we jus knock down the high points and go over it with a new layer of drywall. much quicker than scraping and mudding.. too often the scraping process leaves gouges and damages the old ceiling which takes longer to repair than going new
woodworkbykirk is offline   Reply With Quote
Old 11-05-2012, 11:05 AM   #5
Drywall Texture Pro in Fl
stoner529's Avatar
Rewards Points: 154
I can agree that just knocking off the popcorn balls dry will be sufficient. However, there is going to be lots of dust so wear a mask of some kind that will protect you from this. Make sure your ceiling doesn't have asbestos in it either...Do some research on that if you haven't already.
how to remove popcorn
stoner529 is offline   Reply With Quote
Old 11-05-2012, 11:57 AM   #6
Rewards Points: 2,202
Now if the popcorn has been painted you are in for fun fun fun. doesn't scrape easy.
mae-ling is offline   Reply With Quote
T&G pine ceiling gulbworks Carpentry 5 05-30-2011 07:46 AM
Faux knotty pine Pledger Painting 3 09-19-2010 06:37 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Cleaning knotty pine boards barks Remodeling 4 03-17-2005 09:55 PM
