Knee/Pony/Half Wall Framing? Is This Correct? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-07-2011, 09:27 AM   #1
Rewards Points: 150
Knee/Pony/Half Wall Framing? Is this Correct?
[/IMG]
Pic 1 is what I am trying to achieve, Pic 2 is my proposed framing? Is this correct or how should it be???
Thank You
[/IMG]
Knee/Pony/Half Wall Framing? Is this Correct?-halfponyknee-wall.jpg   Knee/Pony/Half Wall Framing? Is this Correct?-halfwall.jpg
Evil Scotsman is offline   Reply With Quote
Old 04-07-2011, 09:28 AM   #2
Rewards Points: 150
Pics are reversed Pic 2 is what I am trying to achieve! Thanks
Old 04-12-2011, 09:26 AM   #3
- How are you planning on tying the half-wall to the main wall? Does the half wall have a free end/s or does it end at walls on each side?
- At 5.5" depth, are you framing with 2X6 or 2x4? (16" o.c. is fine either way)
- Is this going to be a structural element or is it simply a shelf surface? Shelf and brackets, or a shelf with concealed hardware would be a lot less hassle unless the appearance of a wall is a major design issue.
Scoutsout is offline   Reply With Quote
Old 04-12-2011, 02:38 PM   #4
Rewards Points: 150
The appearance of the wall is what we want. Not structural in any way just to put pictures, knick knacks, drinks etc. 2x4 and would be nailed into the studs of the regular wall.
Opening up a wall - correct reading of span table (R502.5(1))??? DyerWolf Building & Construction 6 07-19-2010 10:37 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
