#1 |
Kite winder for stairs
Any body know a good place to purchase oak kite winders 3 piece for stairs. I might might make them
#2 |
Chicago, IL
Are you in the UK? I've never heard the term "kite winder" used in the US.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 | |
Kite winder for stairsQuote:
The winders are for the bottom three steps in a cape house. Last edited by ianc435; 11-04-2010 at 04:48 PM. |
#4 | |
STAFF
You will not find a place that sells a kite tread as there are just too many variables that will make that tread in different dimensions. You will have to buy a blank and cut it yourself.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Jim |
#5 | |
#6 |
Stair builder
How are you planning on attaching the tread to the rough framing?
#7 | |
#8 |
Stair builder
You don't need a spline or epoxy, just edge glue them together with yellow glue. What you need to be concerned with is seasonal wood movement. If you use construction adhesive and nails on a large winder tread it will split over time.
#9 | |
#10 |
Stair builder
Here is what I do.
Put the winder tread down before the next riser. Then place the riser on top of the winder tread. Since squeaks are usually from wood moving up and down on a nail, I'd put adhesive at the point of the walk line. I.E. the place where you would normally step when using the stair. Not too many nails everywhere else. This always the tread to move both in front of the adhesive and behind it. But to be honest, I always house my treads and avoid this problem. |
#11 |
Hey thanks a lot. I guess i am going to replace the risers on those steps.
I don't mind sqeaks. They let you know someone is there. It adds character to the house, What do you mean by house , i am unfamilular with that term. Do you mean leave them in the house before in stalling them? Last edited by ianc435; 11-04-2010 at 09:38 PM. |
#12 |
Stair builder
Housed stairs are where the stringer is mortised to receive the treads and risers. They are then wedged from below. These represent the highest quality of stair work and assure a squeak free stair. They are however outside the range of a DIY...
#13 | |
#14 |
Stair builder
In that case here is a link to some vids I did on housed stringers http://www.youtube.com/watch?v=xrFdO-y1YVM. These are geared toward stairbuilders. It is a brief overview and does not cover how to layout winders.
#15 | |
| Display Modes | |
