Kitchen Organization - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-11-2009, 08:46 AM   #1
Rewards Points: 85
kitchen organization
Sorry if this isn't the correct place to start this thread, but here we go. The last episode of Ask this old house showed a drawer organizer that maximized a deep drawer as far as from top to bottom, not front to back. I searched everywhere online, but could really not find anything that was basically a sliding drawer, inside a drawer. From the looks of it in the show it looked to have had rails that mounted inside your drawer and you would have had to cut out the back of the drawer so that once the drawer was open, you could slid the top drawer back into the cabinet to access the depth from below...sorry so long, but is there anyway I might possibly be able to construct such a thing with piecing together items from my local home improvement store...thanks in advance
mferguson0414 is offline   Reply With Quote
Old 01-11-2009, 09:09 AM   #2
These are pre-made drawer boxes. Expensive but nice.
http://www.kitchensource.com/drawer-...cc-cd03-21.htm
You can buy just the slides at sites like www.rockler.com and make the box yourself. I'm not sure of the exact one on ATOH, but I did see the episode and know what you are referring to.
jerryh3 is offline   Reply With Quote
Old 01-11-2009, 09:13 AM   #3
Rewards Points: 85
thankyou for the quick reply, after going through a couple threads here, I came across KV...so used my happy little friend Google..and came across this
http://www.knapeandvogt.com/Double-T...ls.191#details
this I believe is exactly what i'm looking for..but your suggestion is awesome too..good to know now that I have options
Old 01-11-2009, 09:21 AM   #4
Fixer of all things Broke
LaHandyman's Avatar
Send a message via AIM to LaHandyman
Maybe a less expensive way to what you want to do is to build a tray and mount it in the draw using a set of side mount full existention draw guides. And mount them backwards so the tray slides to the rear of the draw. And as you mentioned, the rear of the draw will have to be cut out to allow the tray to move. The draw guides can be bought at any lumber/hardware store for under $20.00 a set.
LaHandyman is offline   Reply With Quote
Old 01-11-2009, 12:51 PM   #5
Rewards Points: 85
I guess I would need to get some more ideas about putting that tray together, 20 dollars is alot better than 100
Cheap temporary kitchen flooring idea. ember64209 Flooring 9 01-10-2009 12:45 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 09:31 PM
sagging kitchen off back of house DanBress Building & Construction 12 03-03-2008 10:20 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
