Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-23-2007, 10:58 PM   #1
Default Kitchen floating floor
I was considering starting a project in my kitchen. Basically for some stupid reason the walls have Formica on them, and the floor is a big vinyl sticker or something. Anyway i was considering a pergo type floor. My question is, is it complicated to install and how expensive is it on average per square foot. I know what im doing when it comes to almost any aspect of carpentry, but i never installed a floating floor. I have worked on standard hardwood floors but i am not sure how pergo works. Any help is appreciated, the kitchen is about 13x14 or so.
JFD140 is offline   Reply With Quote
Old 08-24-2007, 08:34 AM   #2
zel
Send a message via AIM to zel
ITs fairly simple. The pieces lock together. You stagger the joints, but you dont have to stagger them any specific way, because the pattern on them hides the seems. If doing it in the kitchen, choose the product that holds up to water the best.
zel is offline   Reply With Quote
Old 08-24-2007, 11:54 AM   #3
In the kitchen you want to use the glue together flooring, not the interlocking type. Prices range from about $2-4.00 a sq. ft. for the flooring but you will also need the cushioned underlayment, maybe a vapor barrier. What you need will be dependant on what you have now. You can spend more for the flooring if you want. Or less with a closeout. Go to any local flooring place and see what you like. Or shop online.
Ron
Old 08-24-2007, 11:52 PM   #4
I put a floating laminate floor in our kitchen. I used an interlocking product from Armstrong that looks like slate. This particular type already had the cushioned underlayment attached. It wasn't cheap at around 4 bucks a sq foot, but it looks good and has held up great for several years. After I finished the floor, I had some scraps laying outside for months. Even after being exposed to the weather, the pieces looked good as new. I have no doubt this floor can stand up to the abuse of kitchen use.
ACobra289 is offline   Reply With Quote
Old 08-25-2007, 01:28 PM   #5
Darylh's Avatar
I installed click pergo 2 years ago for a client and was over the other day for some new work coming up and it looked the same as it did when I installed it. I would think the glued would be more waterproof though.
www.geocities.com/edimprovement
Darylh is offline   Reply With Quote
More On This Topic
I’m Lee. I have a degree in architecture and about ten years experience in the construction field. And we have about finished the kitchen remodel. All we have left to do is the counter tops and decide on something on the floor. The first thing that... Read More »
The kitchen is usually the hottest room in a home. Due to the heat generated by stovetops, ovens and toasters, most kitchens are equipped with exhaust fans. These small, but powerful, fans are usually located inside a hood just above a stovetop. Hot air... Read More »
People are now living to be in their upper eighties, and beyond. This rise in the senior population is bringing the need for safe, accessible bathrooms to the foreground. No one wants to think their elder parents are facing hygiene hardships. Many... Read More »
Carpentry is a skilled profession that will always be in demand. Homes and buildings don't construct themselves. Woodworking that includes building beautiful cabinets and furniture is a part of carpentry. If you enjoy working with your hands, pick a... Read More »
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 05:21 PM
Install floating floor or my doors first? jtr Flooring 3 11-16-2006 11:21 PM
Floating Floor in the kitchen sweetwillie66 Flooring 3 02-12-2006 04:10 PM
Kitchen floor rotted. mtlangr Flooring 3 05-27-2005 01:55 PM
kitchen floor advice Grumpy Flooring 2 02-24-2005 01:12 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
