-   -   Kitchen counter top next to stove code? (http://www.diychatroom.com/f14/kitchen-counter-top-next-stove-code-124617/)
rodm1 11-26-2011 07:38 AM
This photo is the same situation as mine. The question I have about it is the counter top hight. Will the counter hight pass code if like in the photo with counter top above the stove? What are the required hight for a island like this flush?
http://images03.olx.com/ui/5/39/51/1...n-Supplies.jpg
ben's plumbing 11-26-2011 07:44 AM
why not raise stove up by the adjusting legs.....problem solved...are these standard cabinets?
tcleve4911 11-26-2011 07:46 AM
Don't know of any codes governing countertop heights.
Personally, I would raise the adjustable feet on the stove to make it closer to the countertop height.
oops...what Ben said.........
woodworkbykirk 11-26-2011 10:33 AM
the only codes that i know of regarding counter top heights are in regards to kitchens designed for those in wheelchairs.. they must be lower so to allow someone in a chair full use of the countertop
i know there must be a small air space between the stove and the cabinets at the sides
rodm1 11-26-2011 11:37 AM
I'm going to raze it but wondering how much. Are most flush with the top of stove or should it be lower?
Ironlight 11-26-2011 12:02 PM
Most are flush or with the stove slightly above counter level. It really depends on what stove you have and what sort of top it has. If the stove has a rounded lip along the edge then raise that up above the edge of the counter. In general, you don't want the "sharp" edge of the counter showing because it will a) catch dirt and b) look funny.
If your legs won't go any higher then consider putting down a sheet of plywood under the stove to raise it. You can try putting blocks (ply or 1x or whatever) under just the feet to save wood but it can be a real pain to get the stove up on them when getting it back in position.
Bud Cline 11-26-2011 12:17 PM
Ironlight,
The OP supplied you with a photo why don't you look at that first?
NancyNGA 11-26-2011 12:19 PM
Originally Posted by tcleve4911 (Post 779129)
Don't know of any codes governing countertop heights.....
http://i709.photobucket.com/albums/w...leys/shush.gif There will be now.
rodm1 11-26-2011 03:37 PM
Thanks, everyone I just moved the adjusting screws up until flush with counter.
